Today I put a 30cm long x 2mm deep gutter rash on one of the LMGT4s
Very dirty on myself :rant: . From mint to shit in a few seconds
Not to mention how that devalues them and looks farked
What a nightmare! :(
Edited by dontyellpl0x
Ill take them off you if you ever decide :)
  • Like 1
I scratched my LMgt4s doing a Macccaz run was so posses that day.Powdercoated them and was happy again.
Rebuilt my calipers and powdercoated them wth Shiv.They looked great didn't want to put them back on.Whilst rebuilding bought braided lines and slotted rotors and pads. Now I need to find out how to bleed the master cylinder before I give up and take it to a shop
  • Like 3
MObile fabrications in Quenbeyan and Shiv for the calipers. Just some warning powder coat is a thicker layer, some areas with fine tolerances will have to be covered up or your wheels will not fit on the hub
Thanks Bryce - If I need powder coating I know where to go now.
I went and saw Craig at Wicked Wheels. I am going to give him a go for the rim - will post feedback.
seems like a good guy, so I'll see how it turns out before reporting back.
(March 2nd - is a busy workshop)
Anf - let me know if your interested in my R32/4 RB20DET (Auto)
Will likely be putting it up FS very shortly and looking for $10k in my pocket
Or any ACT SAU peeps
Drives beautifully, goes great guns.
1989 M Spec with ABS and Auto Spoiler. 117k kms
Paints very good but does have some stone chips on the bonnet.
Privately Imported into the ACT as a 4b in 2004. I'm 2nd owner in Aus
Full service records since import at 37k kms.
99.99% OEM (head unit and sub)
Things I've done
Major Service, rotors and pads
Aftermarket head unit, 4xspeakers and small 10" sub in boot
Remote keyless entry
Front/Rear bars resprayed
New windscreen
2 full sets of GTSt rims and running on mint 32GTR rims
HD rear sway bar
Newly recovered 32 steering wheel
No dash bubble
Ïnterior & seats etc awesome.
GTR car mats front and rear in really good cond
Small crack on drivers arm rest :(
For those who haven't seen her it is very naice :thumbsup:
Reason for selling. Got my eye on something else more sedate
Edited by Sinista32
Beautiful car and Drives amazingly for a 26yr old. :yes:
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
