I am parting out a complete r32 coupe rolling shell some stuff is gone already such as the stereo surround and dash vents, castor rods, sideskirts and rear pods.
all panels are straight but will require re painting
almost all other parts available such as:
front bar and reo bar - $150 each
mint projector headlights - $230
mint indicators ( genuine clear type) - $140
doors - $100 (shell only)
guards - $80 each
mirrors - $50 pair
door cards -$50 each
interior C pillar trims vgc - $150 pair
bonnet - $120
bonnet latch - $60
stock suspension components - from $20
rear diff - $ 150
seats - $50 each
seatbelts $ 50 each
carpet $100
roof lining - $100 (sunroof)
wiring looms - from $40
fuel tank / pump - will post price once Ive checked out the pump
full 3" stainless exhaust (cat back) - $200
all glass - from $50
rb20 engine crossmember - $150
most engine parts like manifolds and p/s pumps etc - from $20
coilpacks - $130 for mint set (stock ones)
ecu's (rb20det and rb25det) - $130 each
etc etc
I also have some running gear like a rb20det engine that needs rebuilding - $200 and a excellent rb20det gearbox - $550
please note I will be selling all the hubs and brakes as a full 5 stud conversion kit (I do have a spare pair of r32 front hubs and knuckles) which will not be for sale for about a month as I still need to be able to move the car around at this stage
please contact me for prices or photos some parts I will be negotiable on prices some I will not :) and im located in algester 4115
also got stuff like:
manual rwd speedo cable - $80
r32 clutch pedal, master and slave cylinders with lines - $150
r32 cluster $70
r32 cluster surround with working switches - $120
good r32 rear C pillar trims - $150 for the pair
rb25det igniter - $80
rb25det into r32 wiring harness - $250
lots more to come :)
passenger door window switch at anychance? pm me
passengers window switch sold already sorry... also engine crossmember, the rb20det engine and type m front bar are sold
I will be taking offers on the bare shell with no interior, no panels or front windscreen and without the diff or brakes etc, the shell has had a minor front end impact but has straight rails/ rad support etc.
shell is also complied and mod plated for a rb25det :)
r32 clutch pedal, master and slave cylinders with lines - $150 - sold pending payment
also have:
manual alternator/starter loom for -$60
r32 gtr intercooler - $150
2 passengers side headlights one projector one brick type - $100 each
yeah dude I moved over here a few months back :) and yep I've got that bit... do you mean the sill cover thing that has skyline written on it?
If you have still have the upper c-pillar trims, Front door trims and a-pillar trims in a few weeks maybe we can cut a deal. Just gotta recover from christmas/new years money
Hey Adam
Yeah no worries mate i still have all that although there's been lots of interest in the C pillar trims... Let me know when you've got the coin and we'll work something out :)
you still parting out?
hey dude just selling bits I have doubles of at the moment... a guy is coming to put a deposit on the shell on Thursday so probably wont be taking anything else off the shell...
the shell is still for the sale if anyone's keen, its missing quite a bit but would be sweet if you have crashed your car and just need a new body, or would make a good drift project :)
things that are missing:
front and rear bars
engine crossmember
all lights
manual bits like pedals etc
axles
brakes
some interior missing but most is still there
rear rhs lca
mirrors
all drivetrain
  • 5 weeks later...
  • 1 month later...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
