hello,
Im giving my self $2500 for xmas to buy tyres and wheels for my r32 gtr, I dont daily my gtr, and im slowly setting it up fully for track use, what wheel tyre combo do u think would best suit my needs,
i will most likely be looking at second hand tyres at least to fit in that bracket, i have been looking at some r34 gtr wheels with tyres on ebay but not to sure on how they look on 32 :(
https://www.sau.com.au/forums/topic/415848-options-on-wheeltyre-combos-32gtr/
BBS LM 18 x 9 +20
R34 GTR 18 x 9 +30
R33 GTR 17 x 9 +30
All great options. GTR rims are forged and relatively inexpensive. Go 17s for cheaper rims, tyres, and prolly better handling but not if you think you're ever going for big brakes. Hence I sold my mint R33 GTR rims. Wish I didn't.
Maybe R33 for $1,000 and R34 for $1,800 then tyres. Not sure what change you get from $2k for good track tyres but others will point you right I'm sure.
RFP1s are a good option if your looking for something Jap, light wieght, and good quality at a good price.. i looked at some when looking for some new rims, along with the TE37s, but every Tom, Dick and prick has those rims.. so i shopped around and waited for something a bit different
Ended up buying a second hand set of LMGT4s with cheap rubber for a bit over $2500, and damn they look good if i dont say so myself :D
bastard were the hell did you find LMGT4s for 2500 havent seen a set under 3 grand in a long time
Nice!
Always wanted Nismo LMGT4's but car came with TE37's, so can't complain.
What sizing are your wheels?
Yea they are a fantastic wheel, light weight and massive clearance for brakes
They are 18 x 9.5 +15 offset, have some 265 yokie semi slicks going on them..
Got the wheels off another member in Melbourne :)
37s are still a good looking wheel, I was very torn between the 2.. Especially the SL's
Nice!
Do they sit flush under the guards or do they just sit in a bit?
Nice!
they sit flush at the top, at the bottom they poke out a little bit as the guard rolls under the car... looks really good
will look even better with 265s on them :D
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
