Yeah it was Jason
Stinky do you have any more sweet pics of my car? The ones while we were cruising the highway or did my foggy headlight fark them up
no, the driver did.
but srs, post pics?
  • Replies 367
  • 3 weeks later...
Half the calendar is done. I've put them up on my Facebook so some of you may have seen them.
I might have them printed for the Fiscal year or even just start from April (Turns out I can pick any month to start).
Also, price has gone down to $20 each+ postage.
Okay, here is what I have done. I hadn't hear from anyone else so I put together some photos from other thing last year. The last thing I will probably do is add credit to the first photo. Can someone PM me Gabe's and Rob's full name? I didn't end up using Rob's photos, saved them for next year.
Also the calendar is April 2013 to March 2014... the Japanese School year LOL
