Due to financial difficulties, its time for my baby to go =(
ITs a GTST TYPE M Series 2 skyline with ABS brakes.. so its the late 96 model, realeased early 1997...
Includes:
White
5 Speed Manual
ABS Brakes
SRS Airbags
Apexi 6" exhaust tip with 3" piping from turbo back
Apexi front Strut bar
Apexi S-AFC
Apexi Rev/Speed Metre
AVO front mount intercooler (Fitted by AVO)
Blitz blow off valve
Trust Airinx air filter
Tein adjustable suspension (front and back)
HKS Turbo Timer
HKS Electronic Boost Controller (In Cabin)
Sony CD/MD Player
Sony 6 stacker CD
Two 10" Cross Fire Subs
Two 200watt x 2 Cross fire Amps
Viper Alarm with Immobilizer
New Tyres jus put on too (worth $900)
(The Boot is professionally set up and looks awesome with the leather)
Tweaters on pillars (not sure what brand- came with car)
Aggressive Chin Spolier
109,800 kms
Ive only had the car for three months and am the second owner.. Trouble wit cops and fines and its really digging into my pocket.. Cant afford to keep as im at uni and not working much.. Has ALL receipts of modifications done in Australia, and has every single SERVICE receipt too.. Serivce and oil change done every 5000-9000kms.. I've only ever used optimax fuel too.. I have not had one problem with it.. very clean car and great for a first car buyer..
Not one scratch or dint expect for a slight crack on the chin spolier (Approx. $100 to fix).. Awesome to drive..
im looking for 24 k ONO, will be flexible for serious buyer.. Rego until next march.. New tyres put on ($900 worth). Serviced one month ago.. Looking for quick sale..
PM me for more details and pictures...
Cheers
Rob...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
