Cams L2S (Level 2 Speed)
That said... For DECA and some Winton events, a AASA Club Racing licence is also valid and it is a little cheaper. However will not get you onto Sandown, Phillip Island etc if you want to give them a shot as well :)
CAMS L2S = $95/year
AASA = $50/year
https://www.sau.com.au/forums/topic/416384-event-license/#findComment-6684458
CAMS L2S will cover you for pretty much everything you want to do for the year, and it's not much more expensive. 10% discount on insurance with Shannons to if that sweetens it for you. Will basically pay it off, and more ;)
https://www.sau.com.au/forums/topic/416384-event-license/#findComment-6685089
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
