Hope everyone is enjoying their holidays. I just got back from a week in Melbourne with family.
Just so happens I was on the Hume, in Victoria, overtaking a couple of trucks doing around 110kms in my missus I30. Next thing you know a R33 flys up my ass doing about 140kms thinking that he can sit up there about 3cms to push me doing his speed. I wasn't going to have it so I slowed down to 100kms to match the truck's speed, and he really hated it. When I let him go, he thought it be a great idea to cut the truck and then me off, to then brake to cause and accident. Well lucky I had my wits about me and didn't but slowing down to 60kms in the right hand lane of the Hume is the best idea this guy had.
I really don't care, what really gets me is that the truck drivers were parsing me for doing what I did and no doubtlessly thinking another dick head in a skyline. Things like that ruin out reputation and being a proud owner of a better skyline then this bloke (r32 gtr) it hurts.
So if anyone sees this guy, don't be afraid to tell him to f**k off to a commode and stop ruining our reputation. I will be posting this in the ACT and VIC forums because no doubt he was off to summernats.
The car is a blue r33 gtst with a white flame decal on the bonnet and stupid cartoon fast and furious crap down the sides. And the license is Ytb 465 Vic plates.
https://www.sau.com.au/forums/topic/416431-name-and-shame/
Omg... I saw the very same car today when I was buying lunch. He was at Smithfield NSW at 3pm. I cringed at the car when i saw the fast and furious white flames, had a look at the driver and he looked like a twat wit sunnies on.
https://www.sau.com.au/forums/topic/416431-name-and-shame/#findComment-6685374
Yeah its not a good looking car. I have copped abit for posting this, was quite angry at the time.
Mainly because everyone thought I was bagging out r33s. I was only on his. My uncle has a sweet r33.
Yeah I think it will be the last time I do it. Next time ill just ring the police and keep my mouth shut lol.
https://www.sau.com.au/forums/topic/416431-name-and-shame/#findComment-6686430
Agreed, best course of action. I recently had an incident in my wifes Cube, & with my 2yr old daughter in the back. Turns out knobheads in VD SuperShiite wagons don't like doing 50 km/h in a 50 zone. They like to weave around & hang over the double lines (but not overtake, cause that's breaking the law!), then after 3.5km, just before the end of the road with this complete idiot so far up my butt, he decides to start flashing high beams. So i stop & get out. He roars past, but I got a good look at him, plates, make of vehicle & colour. Went straight to my local & reported him. Officer rang me afew weeks later & told me I got all the info right, they had a chat with him. He claims his wife was using the car that night...............GUTLESS PRICK..............!
https://www.sau.com.au/forums/topic/416431-name-and-shame/#findComment-6690429
Courtesy needs to come from all parties.
* the driver in the overtaking lane needs to complete the overtaking manoeuvre without fuss
* the one about to overtake should keep his distance from the one ahead whilst he accelerates.
I learnt my lesson on the Hume and other 2 lane highways after copping stones from trucks and accelerating cars ahead. Tailgating has caused me to lose a fog light or windscreen before.
https://www.sau.com.au/forums/topic/416431-name-and-shame/#findComment-6691959
How f**king irresponsible are you? You slowed down to the trucks speed? I don't even know where to start, you need to hand your licence back buddy.
How irresponsible are you?
You actually read OP's post.
https://www.sau.com.au/forums/topic/416431-name-and-shame/#findComment-6694103
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
