So, apparently my car (I'm not the first owner since import) managed to sneak through compliance without having the HID lights removed. Only problem is that I've moved interstate (NT) and they do a compliance check (in addition to roadworthy) when you transfer registration from interstate.
I'm told I'll either need to have them modified to be self-levelling and have spray washers installed, or change them back to halogen. I assume changing them back to halogen is cheaper, however what will I need to do this apart from disconnecting the ballast? Since pretty much nobody does this willingly I can't really find out what to do and would rather do it myself if it doesn't require actual rewiring (as opposed to changing a harness or something).
I imagine you will need some sort of adaptor to fit the halogen lamps into the existing holder. (Some dodgy compliance workshops glue them on!!)
Then cut the 12V cables that feed the ballasts and fit an appropriate halogen lamp connector.
If you are Planning on re-connecting the HIDs then just splice into the 12V cables rather than cutting. It will make swapping back easier.
Sorry if I wasnt clear; I did already take it in (to the compliance place), and was told as above. Thanks sonicii, I'll have look around and see if there's any places that are confident of doing it I guess.
Edited by ObiV35
  • 5 weeks later...
What they havent told you is that it is illegal to fit a different type of globe into a reflector designed for HID, so fitting the self levelling thing is the only correct thing to do... Just dont tell them that theyve asked you to do something illegal or theyll get upset ..
i'd just take out the HID bulb and use the fog beam instead. There is no reason why you cant use the fog beam as a low beam. According to ADR's, the reflector is within the correct height tolerance from the ground, it is within the right distance from the cars width, and is the correct wattage, it only needs the beam height set...
then once the car is signed off, go home and put the HID bulbs back in. happy days
Are you sure?? can you supply a reference?
It would be strange that the requirement for these cars to meet ADR is the HIDs are replaced with halogens.. when this doesn't comply with ADRs??
Also, HIDs require headlight washers.. not just auto leveling.
its all in here..
http://www.infrastructure.gov.au/roads/motor/design/adr_online.aspx
the section referring to headlamps, and the section referring to filament lamps, both state that the "E" marking on approved ADR headlights will be void if modified without testing and approval, ie: installing a globe that is not the same as the globe type marked on the rear of the light assembly, due to filament and reflector misalignment.
Its up to you what you want to do, i personally wouldnt want to cut the loom and get rid of the HID components.
Just jump through their hoops to get it through compliance and rego.
Mine came fitted with halogens due to compliance. All they had done is unplug the ballasts, jammed a single fillament bulb in there (the high beam is a dual fillament bulb with the fog) and tap a wire from the bulb to the ballast plug.
I've seen a lot of cars have the fog lamps disabled for compliance. Mine had the relay removed in fuse box behind the battery.
Once they sign it off and you have rego, put the HID bulbs back in and plug the ballast back in. Just stick to the low temperature color bulbs (I think it's 4000k?) so you don't attract the wrong kind of attention, like it's really obvious people have HID's when they use 6000k or higher bulbs.
But wouldn't part of the RAWS compliance approval process include testing and approval for headlight modification to meet ADR requirements?
this is the annoying bit. it is as illegal to fit HID globes to a regular headlight reflector as it is to fit a filament globe into a HID reflector. In both cases they are designed to have the correct parts fitted.
as usual, government standards allow a downgrade to crappier filament globes. double standards.
Youll find that the RAWS process only signs off that it is no longer HID, infact they do no testing at all of the replacement install regarding light output
A double standard isn't too surprising from the government.. They probalby just overlook the 'non-stanard' lamp for compliance purposes..
I guess if they leave the HIDs in, they also breach the requirement for HID headlights to have washers and auto leveling.. least of 2 evils maybe??
  • 3 weeks later...
Just to reply back, I got an auto sparky to fix my compliance issue. I was busy/lazy so it took me a while to get around to doing it. It now has modified H7 globes in there but all the wiring is still intact. Only 2 hours labor :) It would have taken me a lot longer, haha.
Thanks for all the info/advice.
the ballasts are disconnected but not removed. I believe a standard H7 socket is in there, spliced straight from the original power before the ballasts? The D2R socket is still in there, just moved to the side. I think he had to modify the frame of the H7 globe so it would fit in the same spot.
see: http://www.consumabulbs.com/photo/499.jpg
  • 3 months later...
how do i see if the balasts is disconnected im not even sure of where theyre located. This is a picture of mine. Could i just plug in the bulb and it will work need to figure this out before i spend on the bulbs and to find i have to do a lot more.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
