Hi Guys,
i am a a newbie to this so please help me out or send me links to where someone else may have asked same questions.
Basically i have a 1993 R33 series 1 skyline manual coupe.
i am in two minds about a couple ideas however i know at the end of the day it depends on cash however 1st of all i want to build a bottom end 1st.
what should i do ??
keep the 25 bottom end and put over sized pistons etc or should i do a 25/30 i think the 30 would be more beneficial for long term and power however there no point wasting money :P
I was looking at spool kits now has anyone had any experience with these guys or any others would hate to out lay the cash if they dont work and need to buy same part again cause they dont fit etc.
as for power i was looking around 350-400kw ish.
Any help that would be great.
Thankyou .
https://www.sau.com.au/forums/topic/416535-help-please-2530-det/
I'm doing basically the same thing as you at the moment.
I'm leaving the rb25 that is in my car and just putting heaps of bolt on mods like Etm manifold gt3582 forward facing plenum new process west intercooler 3inch cooler piping microtech lt16c spitfire coils surge tank 044 external pump walbro internal -6 fuel lines ( ill be going -8 soon) and I'm just going to put that on a safe tune so I can drive the car while I built the 25/30
so what iv done is got a 25 head and a vl turbo bottom end ( doesn't have to be a vl turbo can be just a series 2 needs water and oil ports for turbo) first I'm going to do the head so iv ordered a camtech 426B my mechanic had a set of overside valves so I grabbed them and heaviest set of hydraulic valve springs I could taken the head to local machining shop to fit it all and weld up the vct also while its there open up the throught and do some porting work I'm doing all this befor I pick the pistons so we can get an idea of compression before buy them I have a set of rods with 22mm pins from my vl I'm just going to use them
this is were I'm up to at the moment now it's time for the bottom end work out the oil pump get the crank all machined and collar fitted acl bearings get the block bored I'm going to get a asr sump that's baffled and gated
I'm aiming for a safe 400kw all day everyday hope this helps you with your build
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
