It seems like the V is pretty tail happy... oversteers a lot.. ! I installed Stillen Sway bars over the Christmas period.. took out on a drive.. and it has improved a lot .. less slip.. Front - Soft, Rear - Medium...
However.. I'm still not happy or confident..
I always feel like the tail is going to slip driving in full auto going into fast corners (55km/h)..... Engaging the manual mode however brings back the traction.... but.. I shouldn't have to do that..
Setup Front 245/30 R20, Rear 275/30 R20 - ATR Achilles Sport tyres.. still has plenty of tread..
What do you guys think?
  • Replies 47
What year is your car? I'm guessing it's the open diff. Since you have an auto that's what you've got i do beleive, someone correct me if i'm wrong.
The 6mt car with the "sports kit" 18's and brembos have a VLSD which is better for tracking/cornering and also stops you from doing the 1 pegger burnouts. That's briefly what i know about diffs, definitely not a strong point so if any of that is incorrect someone chime in that knows exactly how diffs work.
Edited by Seano350GT
Ching chong spec tyres is what I think.
Either get some decent rubber under you (and yes it will cost a fortune because of your choice of wheels) OR
Go to front hard, and rear soft on the swaybars, to promote more understeer bias.
I have found mine a bit tail happy in the wet.. in the dry it is fine as long as you don't go silly with the loud pedal..
tightening up the rear suspension with sway bars will only make it worse if you don't also do the front by at least as much. I am guessing the stillen sway bars may be adjustable? If so, maybe try making the front 'medium' and the rear 'soft', and see how it goes.
Hmm.. you got me thinking Seano350GT .. its a 03 V35 with orange stitching on the steering wheel.. which according to research, must be the sports pack. Which also means I should have the VLSD.. ?
Sounds like the consensus boils down to Tyres.. I bought the car a year and a bit ago.. and it came with those 20" .. I must say it looks good .. but I'm after handling..
The Stillens are adjustable.. that was why I set to Front Soft and Rear Medium cut down oversteer .. but you guys are suggesting increasing understeer at the same time ..?
I find that the chassis handles pretty well, for the most part I have run 245 on the front and 285 on the back with 19" rims using Federal tyres which whilst not the most expensive seem to hold the road just as well as the Kumo KU19's I had on before. Kicking the tail out for me is predictable although I noticed its a lot easier to do with 245 compliance rubber on the back combined with the transgo shift kit
Back to suspension school Sonny :P
swaybars-
soft front, hard rear= oversteer bias
Hard front, soft rear = understeer bias.
Try it out - see if you prefer / feel more confident with a different bar setting. If your after handling, bye bye 20's. Back to 18s with some quality rubber, and sort out the handling with a proper suspension set up.
It's a relative increase; it's not like the car will understeer more than it did before.
What Alex is referring to is changing the BALANCE to more of an understeer than oversteer bias.
Using a heavy rear ARB will increase low speed understeer markedly.
If you are chasing handling at all; you are wasting your time with 20's on this car.
You have no sidewall flex to absorb impact or surface change and the tyre just bashes around going all over the place.
Go back to a 19" and get some sidewall. Also, use a decent quality tyre; just because they're wide, doesn't automatically make them grippy.
It wouldn't be a bad thing to get some Super Pro compression rod bushes (Strut Rod bushes) with additional caster; this will drastically reduce the inherent understeer once you start pushing hard.
This will allow you to use your adjustable ARB's effectively. :thumbsup:
swaybars-
You speak the truth my good man. ;)
Thanks Guys... Looks like I'm a noob at this. :unsure: Only starting to learn about performance/handling .. Hypothetical situation ... Same Good Tyres all round.. which one better? 20" has more surface contact = more traction Vs more bounce/compression with 19" sidewall... ?
the internal diamiter of the rim has no impact on the contact area area if the correct profile tyre is on
But the smaller profile (ala 25 profile on a R20) will have a adverse affect as it is less compliant so the suspension has to do more work to keep contact... In no situation when your running a tinyt profile will a 20 have more traction than a 19.. Why do you think drag cars have huge profile tyres. But too high and there is adverse lateral handling effects due to sidewall flex. Its about a blalance, But for a V chassis in no way is a 20in tyre with 25 profile going to be better than the same in a 19 with more sidewall on a V chassis IMO
Idealy im guessing a 18in wheel with a 45 profile (or 40 is its like a 265 to keep a similar rolling diamiter as the profile is a percentage of the width) would be optimal for a V35
Edited by (Locky)
Thanks Locky. I forgot about the correctly profiled tyres doesn't change the contact area.
Can anyone shed some light on VLSD? I'm trying to figure out if my auto 2003 V has it. Other than the orange stitching on the steering wheel, I have no other way to tell visually.
I read with VLSD, both rears would spin? W/o VLSD .. only the right will?
Jack up rear of car under diff. Car in neutral, handbrake off (do it somewhere the car won't move obviously).
Turn a wheel (by hand), if the other rear spins the opposite way = open diff. Spins the same way when your friend puts some pressure slowing down the wheel, VLSD.
At this stage it doesn't matter too much. There are a lot of people out there with good handling cars that don't have VLSDs.
Only tyre pressure and weight on the wheel impact contact patch area.. tyre width, diameter or profile have no impact on contact patch size.
Thanks Guys.. only way to find out if my V has VLSD is to jack it up. Looks like I should get better tyres. I'm so used to 17"s with Goodyear F1 with my old Maxima/Subarus.. and the V's handling is shocking .. I initially thought the ATRs was decent .. not great or good.. but decent..
If I persist with 20"s.. what tyres suggestions? Falken Fk452s? Kumko Ku13 or others?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
