Hi all, I have some tyres and wheels available.
Firstly, one pair of Japanese 3 piece 18 x 11 Riverside Trafficstar DTS +35 offset with 2012 dated Yokohama 295/30/18 050 semi slicks soft compound about 25% tread remaining. $1200 pair
Second, one pair 2012 dated Yokohama 295/30/18 050 semi slicks soft compound only done a few laps about 95% tread remaining. $650 pair
And third, one pair 2012 dated Yokohama 295/30/18 050 semi slicks soft compound about 80% tread remaining. $500 pair
Call Kevin if interested on 0450320347. I can help with freight if needed. user_online.gifreport.gif progress.gif
  • 1 month later...
  • 3 weeks later...
  • 2 months later...
  • 2 months later...
