Hi Abo,
So what do you think of the tiptronic transmission?
I'm thinking of selling my R32 and getting an GTT.
But the only ones available on the market right now are autos... (I'm from Malaysia)
Any thoughts?
How does it perform on track day?
I like it. I always use the tiptronic buttons and it's quite enjoyable. It took a month or two to get used to it but I'm fine now. It's good on the track too. I've been a couple of times. One thing I guess is that it sucks a few extra kilowatts from your motor so you need more for the same level of performance and also engine management is not so clear cut. Manuals you just buy a PFC and that's that. The only thing I think I can reliably use is the Greddy emanage.
Haven't got to that yet though.
Your AFR’s have lots of potential from about 5000rpm, you look a tad rich there. (When my coils actually fire) My car really hammers at 5000rpm to redline. E-manage is a piece of piss to tune, especially if you’ve already had a dyno run and can back calculate the required duty cycle based on your current injector cycles and the AFR readings.
You use the bottons on the track abo? I find the buttons a pain the back side.. but then again the track that I went on has a few twisties. :thumbsup:
The triptronic gearbox definitely suck quiet a few extra kilowatts tho.. :) But more fun..
ed: I wish.
Yotis: Use the buttons all the time mate, that way when you are on the track you will be in sync with your car.
I was out on Wakefield which is quite twisty the other day and had no problem using the buttons.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
