+1 and I'm intrigued to know why tuner didnt try it....if it was responding so well why give up on it....we all know an RB can push further, even if you just did it for tuning then cut it back....it also gives you a safety margin should you hit any overboosting issues down the track..
im intrigued now too.. lol well it was with a 250kw rated clutch, ive no doubt it would of seen atleast 350kw, if you watch the dyno video you can see it backs off after 5000rpm so it had heaps left, i will eventually build a bottem end up and go back for 350kw plus its still a goal...
  • Replies 45
Faaarrrk Mate that thing is already wound past 180km at 6000rpm and still pulling hard its hit like 200km and you haven't even put 1.4 bar into it yet..16psi is about 1.1 or 1.2 bar...Just looking at one of taos charts and its pulled 360kws but only 180kms...maybe its wheelspin on the roller I dunno
Is it you or tuner that doesnt want to push for more?
if i insisted he would push more, but at moment i cant get second to grip, even third is finding it hard and dont have any more funds to spend on tyres so having any more power will just become more wheel spin, but yeah it still has alot of potential lol.. just need more $$$ to throw at it..
I love the sound of it on boost, its just asking for a flogging..
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
