INASNT is no more
ROFL LOL AND MORE ROFL
this is the guy that said "I DON'T WANT CUSTOM PLATES BECAUSE THEY ATTRACT TOO MUCH ATTENTION FROM THE COPS "!!! and now you have the most "come cop me" plates you could probably think of.
I can't believe ol sameer bought them.. horus: you also need a car to go with them don't forget!!!
https://www.sau.com.au/forums/topic/41700-inasnt-is-no-more/#findComment-854227
haha you f*cken dickheads
Im not putting em on my next car
they will be for show/maybe another car, but not the line
and sif badboy thats noof, Im not the one f*cken preying on my students at work :P
yeah i thought i smelt jail time
https://www.sau.com.au/forums/topic/41700-inasnt-is-no-more/#findComment-854582
