what weight are you running?
10w40 would be the go, Gulf western oils are pretty detergent heavy so running some of that at 5000km intervals should eventually free it up
otherwise you can do what i did to my 31
4 litres of cheapy GW 20w50 (~$13)
2 x Nulon engine oil flush
Dump current oil (save it if you want and put it back in after)
Insert cheap oil + both oil flush bottles
Run for 5 mins at idle, do not drive it!!!
lift the revs to 2-3000 rpm for 20-30 seconds
idle for 5 mins
lift the revs
etc... do it so its running for around 20 mins
dump the flushing oil, change the filter, put new/previous oil back in
party
https://www.sau.com.au/forums/topic/417381-s1-tappets/#findComment-6699521
Nulon make a tappet quieting product
The retail version is different to the one supplied to mechanics tho, if the 31 needs it I go to an ultra tune and ask them to get a bottle in for me, usually works out at about $10 anyway but the bottle says "not for retail sale" or something like that
Glad to hear you got it sorted tho
https://www.sau.com.au/forums/topic/417381-s1-tappets/#findComment-6714997
    • Yeah i found that alot of parts can be wrong or "very" hard to get the real right one. I already bought some brakes years ago on me "old" GT calipers and they were wrong too 😄  I told them too. Even send them pictures...but they said "EBC catalogue has them on my car... So i dont know what their answer will be. I call monday them and let them know that they are really not on my car. If they were they would be already on a car...
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
