Part:
RB26/30 long motor
Condition:
Built but never run :(
Description:
Typical story, got rid of project car due to purchase of house and the wife was pregnant with my first child...now the wife is pregnant with the second kid and I have a bathroom that desperately needs to be redone.
All up I remember spending around the $14,000 mark, so my loss is your gain.
More info:
- A8 block (bored, honed, decked)
- R32 GTR head
- HKS gaskets
- Head cleaned and serviced
- shot peened and linished conrods
- Crank/oil pump collar
- Crank balanced
- rotating assembly balanced, crank grub screwed and fitted with colar
- ACL forged pistons
- ACL bearings
- GTR Oil and water pumps
- HKS adjustable cam gears
- HKS cams, unknown model...didn't think to check before delivering to builder and he said he couldn't find a model number on them.
There are bits missing from the motor, including all the AAC gear, loom, valley and cam covers...This would be the perfect upgrade for someone that already has an RB26 that is looking for a bigger bottom end.
8.8:1 static compression (quite high for a 26/30) this was from my request during the build for better off boost driveability, I can't remember the exact combination that we used to get there, but it also included decking the block a little. Feel free to post questions, but remember it was a while ago now so my memory is a little vague
Blacktown, NSW
Contact Details:
[email protected]
PM on this site
I'll include my mobile number to serious people
Asking Price:
Looking for offers above $6,000...feel like I'm low balling myself
Or, feel free to offer something of interest...you never know
Pick-up/Postage Arrangements:
I'm willing to transport it inside the Sydney area...but you'll owe me a beer when I get there
https://www.sau.com.au/forums/topic/417541-rb2630-long-motor/
I'm not interested in separating, sorry.
No photos of the build, it was done by MRC Dyno Services (Castle Hill, NSW)
I've got 2 of the 3 receipts (lost the first one)
http://i225.photobuc...8may09page1.jpg
http://i225.photobuc...8may09page2.jpg
Images of the long motor
http://i225.photobuc...fsomecovers.jpg
http://i225.photobuc...ginebuilder.jpg
http://i225.photobuc...26inletside.jpg
It also comes with the throttle bodies, inlet plenum, half the loom (been hacked up, probably better thrown away)
EDIT: The harmonic balancer is from an R31 Skyline
Edited by NXGriffo
Anyone recovered from buyer's remorse after the Christmas Period? Maybe you'd like another round of spending...look no further, beef up that Skyline with a properly built 26/30, not just another slap together hybrid.
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 2 years later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
