  • 2 months later...
for some reason i can't pm on here jase but send me a text cos i'll forget - the bloke who bought my stag was looking to do the conversion and i think he just did a fair whack of damage to the front bar so might be a good time to get in contact with him
Hi mike yeah already talked to old dolphin he is not quite ready yet ! I thought about doing conversion my self but kind of like owning a s1 with s2 rear and a neo in it and still love the nismo kit .
Sorry goodo I did send some pics but got no answer maybe I sent to wrong number will ree send
Cheers
Jase
possible to get a postage quote to victoria? 3818. been thinking about selling off all my Takeros gear and going R34 front end for a while now, it would be good to do it while half my engine is apart getting rebuilt.
Edited by OMY31T
  • Like 1
  • 1 month later...
  • 1 month later...
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
