Hi all,
New to the forum/site, just recently purchased my first skyline. 1989 R32 GTR love the car a lot already!
Don't know to much when it comes to these cars i can do the basic's here and there but nothing to full on, hoping that you guys will be able to help me with any problem i may come across with the legendary RB26DETT.
If anyone knows a good spray painter in Perth that they could refer me to i would really appreciate it.
Brief list of mods that came with the car when it was purchased:
Engine:
Apex'i Air Filters
Silicon Hoses
Exedy Single Plate Heavy Duty clutch
Superspark ignition coils
3" Kermit engineering Stainless Custom made catback and cannon
3" Front pipes
High flow cat
Nismo sway bars (front and rear)
Nismo strut braces (front and rear)
Suspension:
Tein Flex Coilover
Whiteline Bushing
Exterior:
Desmond Regamaster Marquis Promada Super Forged 17x9.5 +18
V-Spec Body kit
https://www.sau.com.au/forums/topic/417718-newbie-from-wa/
Welcome Dylan!
Naice - Kermit is the man!
Check out the WA sub-section and join SAUWA, we're doing a SimWorld night soon!
https://www.sau.com.au/forums/topic/417718-newbie-from-wa/#findComment-6706102
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
