  • Replies 71
Jou hele familie se fokken swart poes.... Dom moer!
wat are you, 2 f**king weak to say it in english?
drink another 6 beers and do it again mate, hopefully you'll become another one of your road toll statistics.
pull your bloody head out of your ass and grow up. australia isn't like south africa, and frankly we dont give a flying f**k about how cool u are by driving at 200kmh while drunk. go boast somewhere else
nugget:
relax mate, no need to get so pissed off, he did not come on here boasting, he just came on saying how it is in south africa, u dont see him disrespecting you or australia.
like cyrus said its about different cultures.
and i dont think you spk for every australian, there are some that are interested in broadning their knowledge about other countries and cultures and the performance car scene in these different countries
