Hey I will be taking off my turbo kit in the next few weeks as I am chasing more power and going big single
Kit consists of
2860-5's turbos (ported and smoothed rear housings for max flow)
Tomei manifolds
Tomei dumps (heat wrapped)
HKS front pipe twin 70mm to single 85mm
Nismo AFM's (one is slightly damaged but works fine)
ARC induction box
Apexi PFC
The turbos manifolds and dumps are about 5,000km old
Only ran 20psi for 2,000km!!
In this time the oil has been changed 3 times!!! Yes I am obsessive!
Would like to sell the turbos manifolds and dumps as a kit for 3k (cost me over 4k)
But will part if there is enough interest
ARC box $400 (discontinued)
Nismo AFM's $400 ($800 new)
HKS front pipe $300 also heat wrapped  ($800 new)
Happy to do a package deal
Cheers Ryan
0425573330
In Perth
https://www.sau.com.au/forums/topic/418009-big-gtr-low-mount-kit/
Happy to see it go as a kit cost me alot of time and money to put this kit together
Should make 380+kw if set up right
Also make full boost under 4k so quite streetable :)
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
