Gtr33 Veilside Combat R
1996 Model
41,000 Km's
Genuine Veilside Body Kit (Non Wide Body)
Ex Veilside Show Car, Japan.
RB26DETT
GTSS Turbos
K&N Air Filters
APex'i Power FC
Trust 4" Exhaust
OS Giken Triple Plate Clutch
Cusco Radiator Cap
BC Coil Overs
Water Spray Injector for Front Mount Intercooler
Veilside Gear Shift Knob
Defi Gauges:
Oil Pressure / Oil Temperature
Water Temperature
Exhaust Temperature
Boost Gauge
Rego has ran out but car is can be registered.
Price $24,800
Contact: Alex on 0433-878-905 or PM / Post In Thread.
Also have 3 more GTR33's avaliable.
Edited by Tim GTR
Hi, Jarrad,
I have 3 GTR33 that I have kept for a while
1. 95 Mid-night purple geniune 40500 km Stock motor and turbos, FMIC, Tien coilovers, s/s big 3.75" exhaust, 320km cluster and center gauges rear pots, OS triple plate clutch $24800 rego expired . RWC no problem
2. 95 white 10500km with Yokohama Racing Gallery built forged engine certified at 400PS ( around 303kwaw, Ni turbos, big injectors, 272 cams, triple plate clutch, Ohlins front/Tanabe rear coilovers. FMIC,big 3" exhaust,320km cluster centre gauges. 400R front bar with 19rows oil cooler.
$23800
3.95 silver 10800km fully forged engine and balanced,272 cams, Arias piston, Nismo 1000hp rods, GTR34 N1 crankshaft, N1 oil pump,HKS 2530s, triple plate clutch, HKS fuel rail, HKS Front mount cooler, 2 pieces front rotors,,HKS 3.75" exhaust. HKS coilovers, oil filler cap, rear pods, 320km cluster and center gauges. engine on run in tune expecting around 350kw on pump fuel $33000
Can send pics on request
cheers
Alex 0433878905 email [email protected]
Thanks for coming to test both cars. Found out why the white one stopped , The Nismo 320km cluster I put in has a faulty fuel gauge. Put 20 litres of BP98 into the tank, It starts and run like a beast. The original cluster has 105900km. Nismo cluster reads 34500 which not the true mileage of this car with a Japanese built forged engine. Will get instrument people to repair and check fuel gauge. Being a white face Nismo, would be difficult to replace.
cheers
Hi, The buyer of any of the 4 GTR33 can have a choice of wheels and tyres combo
Veilside Combat R has the 18x9.5 + 22 SSR mariot for Veilside. That fill out the wheel arch quite nice.Hence the following 3 set of wheels and tyres are available as a choice.
GTR33 OEM 17X9+30 PCD 114.3 with Falken Azenis 255/40/17 905 thread
or GTR 34 18x9+30 OEM forged wheels with Dunlop Sport 3000 95% thread
see pics
cheers
  • 3 weeks later...
  • 2 months later...
 Share
    • May as well buy an R35 at that point
    • Yea I also was under this impression from various sources, but I figured it applied only to high speed I/O. I was not expecting any impact on such a slow input. Haltech should have an official statement of limitations or comm rates for these.
    • I get that impression already from various youtube vids whenever the I/O expanders are discussed. MCM, for example.
    • According to @acsplit apparently the forum is being migrated from one server to another so should be back up and running once the migration is done.
    • I thought I would share a few fun facts about Haltech products that I've learnt with their use that they don't share on their website. Haltech GPS speed - Extremely slow to react. It's fine for puttering around but I have no idea what speed I'm driving when in WOT due to the slow response time. This was always going to be temporary as I need mechanical wheel speed for eventual torque management, but it has just been bumped up a priority or two as it's a nuisance.  Haltech I/O Expander - You often hear the response time is slow due to canbus comms, but I could not find concrete evidence and Haltech makes no mention of it. We'll now I have it. I mentioned in an earlier post that I thought my WMI mechanical pressure switch was causing a delayed response from my AEM WMI Controller to my ECU. My WMI begins to operate at 11psi, but my ECU was only getting an "On" signal around 19psi. After removing the pressure switch, there was no change. Luckily I connected my WMI Controller directly to the ECU the morning of my Dyno tune and there was a large improvement. I get the "On" signal around 13-14psi now. These remote IO boxes should be marketed for only non-critical I/O.
