Hi guys
Just received my Defi Din gauges and i plan on running one of the gauges as oil pressure as it would be far more accurate then the standard gauge..
my question is can i have both the standard and aftermarket gauges both reading oil pressure as i dont want my standard one just sitting there lifeless
is it a simple matter of just splicing into the wire and running it off to each gauges? will that give a false reading, inparticular on my defi gauge?
Cheers
https://www.sau.com.au/forums/topic/418164-running-twin-oil-pressure-gauges/
So the defi sender cant be used on the standard oil pressure sender is...
Your saying i must use a sandwich plate for the defi gauge? or are you saying i need the sandwich plate to run both?
