gday ive just got my new toy a c33 laurel and got it for a good price everything i want only problem is it is auto so will all know what the first thing that needs to be done what i need from some one that has maybe done this before and is in the now how is what parts i need to do this the car has a rb25 in it and i know parts for the laurels are hard to find i have found a few like dash cluster and gearbox its self and some interior parts but other things like what pedals can i use and are they the same as say a r33 or r32 if some one could give me a list of things i would need would be great
thanks
thanks
I was going to do this on an A31 Cefiro but didnt. I did a bit of research etc and have an idea on what parts you need:
Box
Clutch
Master Cylinder
Tail shaft
Pedal box (I was told an R32 pedal box would fit in the ceffy so its likely to fit the C33)
Hand brake assembly (my ceffy has the old school foot brake)
Shouldnt have to change ECU etc as to my knowledge these run independent boxes.
I think thats about it from memory. Hope this helps
Yes the pedal box fits both A31 and C33, you also need a manual brake pedal (narrower), and manual footrest (also not as wide as the auto item)
Auto transmission is run on an independent ECU, which is located in the driver's side kick panel, the engine ECU will run fine without it. The only part you need to worry about there is rigging up the neutral-position sensor, or bridging the connector, to trick the car into starting, otherwise it will won't think it's in park/neutral and the starter circuit doesn't work.
So the box has its own ECU? is that then connected to the engine ECU or its just on its own?
Everything between Cefiro and Laurel is interchangeable except rear door cards, glass and fixed body panels.
They're the exact same chassis with a different shell on them.
Is that right? I didnt know that. Good news as I may be wrecking a ceffy soon (if it doesnt sell) and if parts fit on Laurel, well that means bigger potential market for me.
really thats a sore i can relax on the manual interior parts now and just have to sort tail shaft and crossmember out ive read that crossmember 'B' is the one to use and have checked my mates crossmember on his factory manual c33 and it is a B but will it fix with the 25 box thats the question fingers crossed as we both are about to take on the same things
Does this apply to C33, C34 and C35 Laurels?
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
