due to a over eager mod my last thread was locked yes i didnt list prices straight away but was going to put them up when i got home, didnt need to lock after only a couple hours just a reminder to put up prices, i have read the ruls and was in a rush thought i would just put it up to get the ball rolling. hopefully theres enough detail this time.
picked up another r33 gts-t to strip 1995 series 1 its the bluey/green n silver 2 tone
1995 turbo manual
(running gear on hold)
blitz adj coilovers $850
hicas lock bar $60
big straight through exhaust gotta check dump section sounds really nice $350
front strut brace $50
rear strut brace $80
rear brake set up with 5 stud $500
front brakes, calipers/rotors (i have 2 sets) $250 each set
stock diff (will confirm) $150
Half shafts $120 pair
Volk TE37s 18x8.5 18x9.5 +35 offsets 70% front cheap tyres near new 595 federals rear, price im unsure chinese copys 800ish new 3000ish genuine these with lame offsets n decent tyres few marks etc $1800?
complete interior to part:
centre console $80 (will check condition of hinge)
dash surround $100
good condition seats front and rear $250
drivers window switch $80
window regs n rails $150 pair or $80 each
alpine 6x9s $40
some splits in the front (will confirm brand) $60
momo wheel n boss kit $150
let me know what parts you need, will add items when i think of them
located northern suburbs ADELAIDE
may post smaller items
please PM me for number Cheers!!!
  • Replies 60
Posted Images
few more pics....
rear wiper set up sold pending payment
many ppl asking about the wheels i will try get them off this arvo, gotta find some old sockets as they have bloody lock nuts on them and i didnt get the key with the car grrrr
still have some s1 headlights from another wreck $250 the set, the ones on this wreck seem ok to but a bit dirtier, mind you i havent washed it yet :P
stock front bar and reo front bar is damaged, bar indicators fine,
also found a anodies blue rb25 main drive pulley (harmonic balancer replacement) $50
stock dump n front pipe $50
now have 2x stock cooler set ups $50 each
$1600 for volks
$750 for near new blitz coilovers (with stock stuff for trade)
also have a polished surge tank $50 (i need duel outlet for e85)
also may trade any parts for parts i need..
bosch 044 pump, braided fuel lines, suspension parts anything for rb s14 build :P
also forgot to mention that the car has a sunroof which is working perfectly, found out these arent cheap usually 5-800 from wreckers over a grand new. i will say $400 with what ever i can give you to make it work :P
rear strut brace $60
pioneer stereo mp3 with ipod and usb ports at the front $100
series 2 silvers rear wing $30
dash surround $50
seats front and rear good nick slight fade rear $150 the set
sunroof $300 everything you need
full exhaust aftermarkt 1 piece dump/front, cat (unsure if hollowed) 3" (i think) straight to rear muffler sounds really nice can hear running for the next week or so $300
Complete rear brake set up hub/knuckles/lcas/rotors/discs/handbrake set up with cables $400
2ltr polished surge tank $50
offers on all parts listed in original post :P
VOLKS $1500 (need some shitters for car to roll)
VOLK PRICE DROP
had a good once over the wheels few marks 2 rims have dents, one rear like its gone over a bump to hard, and other on the inner side, car still drove fine, so rerolls needed if you want them perfect, tyres are near near 265s 595 federals on the rear abour 80% fronts
****$1300****
a mate has placed a deposit on running gear but said if someone has coin and needs a running gear to let it go and he will get the next one :P $2000 engine box loom ecu clutch red jacket coilpacks feels strong and smooth!!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
