Hi all,
Just joined, so do forgive me if posting a 'hello' post is not allowed or if I'm doing this in the wrong section.
Anyway I joined as I'm a Sydney-sider looking to buy an R32 GT-R and (in addition to everything I've already read here) any advice is more than welcome.
I've also seen several cars for sale here but the threads have since gone cold, so I'm hoping to be around for the next one that pops up and grabs my attention.
Mechatronic engineer - F1 aficionado - former F3 mechanic - motorsport purist.
Cheers,
James.
https://www.sau.com.au/forums/topic/418823-new-member/
  • Replies 41
Thanks gents,
Either is fine really but if modified (be it slightly or worked) it has to be clean with appropriate documentation.
Will primarily be a track car for a few outings per year but that doesn't mean I want to be doing any form of major rework (unless the price is right).
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6727437
does it have to be a 32?
and a gtr?
mark is selling his 33, very cheap for what it is.
have seen it in the flesh, car is meticulous.
http://www.skylinesaustralia.com/forums/topic/418712-r33-gtst-2530-500hp/
Doesn't need to be a 32, but I don't want a 33 (nothing personal, just don't like the look of them), and a 34 is most likely out of my budget so I'm left with 32. I do have a sweet spot for their look though, I must say.
GT-R is preferred, yes.
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6727489
Sweet spot for the 32, that is.
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6727494
Been playing with the idea of stepping into a 32gtr over the 34gtt.
Still early days and might not end up doing it.
Cheaper to modify by a long shot! Just get Benji to help you pick one :ph34r:
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6727956
He'll be my #1 info source.
Good information isn't far away.
Yep I'll soon let you know the originality of the panel gaps, whether all the seams are in tact, which panels have copped a fresh lick of paint, and a quick look under the car will show whether the car has had structural damage etc.
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6728000
Its the only gap you will be seeing Benji :P
Now make yourself useful and go help James find a nice GTR!
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6728023
mines all original, with champaign paint, yellow engine bay, and 26/30....
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6728143
sweet jebus i can't recommend mark's 33 enough
and what's wrong with having a boat? YARR WE CAN SAIL THE SEAS AND PLUNDER BOOTY
That would require an offshore powerboat license! That is one quick boat!
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6728168
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
