Hi guys,
not sure if this is the right section for this but i assumed this would be the place for the best help
Ive bought a set of defi din Gauges and im "trying" to install them into my R32 GTR.
Ive removed the standard set of Tri gauges but i can not for the life of me figure out how im going to mount the new set of gauges as the unit is a different size and has completely different mounting points.
is there anyone who has done this or has any bloody idea how i can mount it securly and make it look neat?
cheers
https://www.sau.com.au/forums/topic/419086-installing-defi-din-gauges-r32-gtr/
Maybe show us some pictures. I have fitted some defi's in single din slot above the radio before and they were a direct fit. It was on a gtst which shouldn't be any different. They were the 3 gauges in a row and single din.
Yes i see what you ve done there, i was hoping to mount the gauges up the top though.
i guess the gauges could sit at the bottom
i have a bit of an idea what i would like to attempt, ill put it in my next post
so in these first 2 photos you can see the gauges dont fit up in the top teir as they are too wide and the centre console becomes narrow
so my idea is to Shave back the inside of the console housing using a die grinder
then attach a bracket each side of the unit with a small 90 degree bend on the ends for mounting
also weld a nut onto the back of the bracket so i can put a bolt through the other side
and then use this mounting hole with a washer on the front face
though this method will leave a substantual gap at the top, the next photo is an approximation in the top left hand corner
hope this is easy to read
Sounds like you have it almost sussed. I forgot that the gtr and gtst climate control are different. If you got a gtst one you could put that at the top and gauges in the middle. Those gauges are really meant for the bottom 2 slots.
no i havent tried that yet but it does look like it would fit, like i said i was really hoping to have the gauges at the top where the old gauges use to be.
Any ideas on how to fill larger gaps if i end up having any? the defi gauges are a bit thinner top to bottom then the standard ones
If you have a look closely at my picture I put a length of black rubber hose between the gauges and the radio. It looks quite neat. Personally I wouldn't cut anything just incase you ever want to return it to factory. Thats just me. Im obsessive when it comes to this as some would say.
here is a pic of your idea brad, climate control isnt mounted though its just sitting there,
ive looked at it and the climate control is going to be harder then the gauges so i may just go with the original plan of die grinding some of the plastic out.. it wont be able to be seen anyway as it will be covered by the consol cover
Yes I realise they fit in the bottom 2 slots.. Though how are you supposed to move the CD player/ climate control to the top because they sure as hell don't bolt straight in
This may help you
http://forums.gtrcanada.com/gt-r-project-cars/57683-trinigts-project-r32-gt-r.html
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
