Hey everyone,
I'm after some help. Im trying to check the timing on my rb20det. Am I right in saying that number 1 cylinder is the first cylinder after the inlet and exhaust cams.
I hooked my timing light up to the black loop wire at the back of the motor and my harmonic balancer degree was about 35 degree.
I want to hook it up to number one plu to check that the other reading could have been possibly doubled.
Also I have a autronic Eccu and a auto trans. What should the timing be set up to?
Can anyone help me out?
Thanks in advance
https://www.sau.com.au/forums/topic/419143-rb20det-timing/
number 1 cylinder is the front cyclinder.
the wire loop sometimes gives false readings. the most reliable way to test the timing is to get an old fashioned ignition lead and remove the coil pack from number 1 and put the ignition lead between the coil and the spark plug and hook the timing light up to that.
timing wise, i think the auto is supposed to be slightly different to the manual by a degree or 2 (it's been a long time since i looked it up). the manual is supposed to be about 15 degrees BTDC. if you are getting 35 degrees then i'm guessing that it's obviously no where near the timing marks on the crank pulley?
https://www.sau.com.au/forums/topic/419143-rb20det-timing/#findComment-6734401
Ok, didn't realise the timing marks went to 30 degrees on those.
As for introducing the lead, you just pull the coil pack out (leaving it plugged into the wiring harness), get an old ignition lead and plug it into the part of the coil that goes over the top of the spark plug, and the other end onto the spark plug. Then clip the timing light onto the lead and test the timing as normal.
Also search to find out the correct procedure for putting the car into timing mode. for example, with a r33 you warm the car up, turn it off, unplug the tps and then start the car again. This is supposed to lock the timing at 15 degrees (it will normally fluctuate a small amount). Also make sure the car is warm when checking the timing, even if not locking into timing mode.
https://www.sau.com.au/forums/topic/419143-rb20det-timing/#findComment-6734524
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
