  • Replies 62
I'm lighter then you, I know your jelly of my body ;) (87kgs of man muscle) ;)Ill run for real sports like league lol
yup and i can still run 2.4k's in under 9 mins. at 95kg.
at 90, it used to be 8:10 but oh well. im not fit anymore.
Runninga for girls.... Anyway apologise for shit carnt mood had 2 hours sleep last night
your all good man. i cant run very far anymore. too many knee ops. but give it a go man. very theraputic. ipod in sweat out.
Nah I can't run my left legs are f**ked from football :(
I do a fair bit of push bike riding I enjoy that lol
115kgs worth.
and unfit as a mutha.....
feel ya bro... after last knee op. got too 112kgs. that was a year ago. 95 now. just thru diet.
once i hit 90 i can walk. 85 i can run. doubt ill ever get to 85 again tho.
i honestly cant wait to shift these last 5kgs man just being able to walk a couple of k's after dinner.
if your knees are up to it i recommend it bro.
Check your supermarkets (including the Asian ones) for this http://en.wikipedia.org/wiki/Konyaku
I use it to replace potatoes/rice/pasta etc. It has worked really well for me. Has no taste on it's own - unless you get the coloured ones for example the greenish or green flecked one which has seaweed in it. I stick to the flavourless and let the meat/vegies and sauce handle the taste. Really makes you feel full even though there are almost no calories or carbs in them and they have high fibre.
Also eat your last meal of the day as early as possible and if you can do some kind of physical activity afterwards. I ride my pushy a fair bit to.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
