ok well.... today was tune day was half bad and half good dropped the car in there at 8 brad is super easy to talk to and explains everything about how he is gonna do it as its my first car that I've had on a dyno left it with him and went back to see how things was going looked at the dyno screen and seen big numbers 270 280 288 was thinking the best he then explains to me that there is problems with the ecu (last thing i wanted to hear) problems being that the ecu must have a bad earth and is making the air fuel mix jump and the water temp is jumping all over the place and tps sensor is not hooked up or not working these combined is making it hard to tune up top and i have a miss that is made by old spark plugs and and shit yellow jacket coil packs i have stock ones that im going to swap back in and have new plugs that tuner has gapped and once i have got my mate to fix the wiring its back to the dyno for more power!!!
just driving it tho its already like a new car amazing power and idle is now perfect with a awesome sound as the tuner said its fine to drive around and to boost is fine but not to thrash it or track as it could end in a big bang
so fix issues and back to finish tune :)
Yeah it is and the power is actually scary to me as I've never had anything close to this much power and every one Tells me there gonna be more once its finished cant wait haha... But yeah the ecu is a bit complecated as it uses the stock computer to power basic things like the fuel pump relay and other relays so its gonna be a test each wire job I'm lucky I have a mate that is a auto elec so he knows what's going on and should be able to solve the problem!!
talking to my mate the auto elec and explained it abit more as im running a map sensor not a air flow meter i require a air temp sensor that is missing!! for some unknown reason and with out it can make the motor lean out install one of them save my motor from going bang!! fix gitter on other sensors mad by bad earth and we are back on track just shows how wiring and simple earth plays such a huge roll!!
Yeah spell check trying to ruin my life haha.. Yeah mate done a 286kw run but the ecu playing up was abit all over the place will go back on in a week or so once the ecu is fixed and see how much it can really do!!
18psi im happy with it tuner said it done it easy no timing in it and only a basic tune and had coil packs braking down up top so that wouldn't help keen ti see what it will do round 2!!
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
