ok well.... today was tune day was half bad and half good dropped the car in there at 8 brad is super easy to talk to and explains everything about how he is gonna do it as its my first car that I've had on a dyno left it with him and went back to see how things was going looked at the dyno screen and seen big numbers 270 280 288 was thinking the best he then explains to me that there is problems with the ecu (last thing i wanted to hear) problems being that the ecu must have a bad earth and is making the air fuel mix jump and the water temp is jumping all over the place and tps sensor is not hooked up or not working these combined is making it hard to tune up top and i have a miss that is made by old spark plugs and and shit yellow jacket coil packs i have stock ones that im going to swap back in and have new plugs that tuner has gapped and once i have got my mate to fix the wiring its back to the dyno for more power!!!
just driving it tho its already like a new car amazing power and idle is now perfect with a awesome sound as the tuner said its fine to drive around and to boost is fine but not to thrash it or track as it could end in a big bang
so fix issues and back to finish tune :)
Yeah it is and the power is actually scary to me as I've never had anything close to this much power and every one Tells me there gonna be more once its finished cant wait haha... But yeah the ecu is a bit complecated as it uses the stock computer to power basic things like the fuel pump relay and other relays so its gonna be a test each wire job I'm lucky I have a mate that is a auto elec so he knows what's going on and should be able to solve the problem!!
talking to my mate the auto elec and explained it abit more as im running a map sensor not a air flow meter i require a air temp sensor that is missing!! for some unknown reason and with out it can make the motor lean out install one of them save my motor from going bang!! fix gitter on other sensors mad by bad earth and we are back on track just shows how wiring and simple earth plays such a huge roll!!
Yeah spell check trying to ruin my life haha.. Yeah mate done a 286kw run but the ecu playing up was abit all over the place will go back on in a week or so once the ecu is fixed and see how much it can really do!!
18psi im happy with it tuner said it done it easy no timing in it and only a basic tune and had coil packs braking down up top so that wouldn't help keen ti see what it will do round 2!!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
