Well I'm alive I won't say well yet but they are all happy with progress, if I could post pics from phone I would post the scar it's like 2cm wide and from ear to ear dead straight, still don't know I'd it's mAlinNt for another week but surgeon say regardless it doesn't matter now as he got it all out so no need for chemo etc which is great news!!
YorthinkinsostraitUcanswopyorbrainwifmineanytime!!!
Nice one scott!
all u need now is pen and paper and access to nengun / importmonster / rhdjapan etc to keep you busy and start putting together the next phase of your GTR plan :)
chalk one up for the man upstairs
Absolutely for man upstairs, problem is surgeon doesn't want me reading , he said if we operated on your leg I wouldn't use it right? He said with brain it's hard cause its always working and u must listen when it tells me to stop which I'm hoping I'd after u design my nos system lol
actually if the doc doesn't want you to think too hard FnF is the perfect movie to watch :laugh:
All the best for a speedy recovery
So true.
"Relax! Don't push it! You embarrass me!"
Dominic tells Vince to stop embarrassing him - just hilarious and do not need to think for that movie or did your surgeon tell you can't laugh as well ;)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
