  • Replies 70
How much for turbo exhaust manifold sent to Adelaide 5013 please
Regards
Allan.M
Sorry mate, motor is staying whole as is.
How much for the power steering pump? Would need postage to 4512
Thanks
$170. Can post to anywhere in aus.
how much for:-
- Power steering high pressure hose
- Passenger power window switch
- intercooler piping if available
would need postage to 4558
PMed
Sold:
Headlights
Front Seats
Rear pods
Boost Sensor
Charcoal Canister
O2 Sensor
Left Guard
Lock Set
FMIC
Skyline Badge
Nissan Badge
Rad shroud
Visors
Center Dash Lower Trim
A/T Gear Knob
A/C Fan
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
