Read this before you open the pictures
Thought everyone might be interested in these photos of a snake caught on an electric fence on a sheep & cattle station near the NSW town of Nyngan.... Some tourists on holidays came across the snake caught in an electric fence, being continually shocked, and getting very angry!
The group wondering what to do, decided to divert the current, cut the wire AND let the snake go! (Thinking this was the humane thing to do).
When the property owner found out he went ballistic, besides being upset about his fence, the snake had been eating lambs in the area, and he'd been trying to track it for ages. He did not appreciate the help!
Australians are used to a big snake or two, but wait till you see this old fella!
  • Replies 1.7k
Posted Images
when asking average men about the best ballet dancers...
average russian man says, (with annoying accent)
"Russia has the best ballet dancers in the world'
English men say (in their very snobby accent)
"The best ballet dancers in the world come from the english ballet company"
Average yobbo aussie with the sun tan and the surfie accent says
"Our poofs will beat ur poofs any day"
The Boss was in a quandary.
He has to fire somebody.
He had it narrowed down to one of two people, Debra or Jack.
It was an impossible decision, they were both super workers.
Rather than flip a coin, he decided he would fire the first one who used the water cooler the next morning.
Debra came in the next morning with a horrible hang-over after partying all night.
She went to the cooler to take an aspirin.
The Boss approached her and said: "Debra, I've never done this before, but I have to lay you or Jack off."
"Could you jack off?" she says. "I feel like shit."
Osama & a large group of his followers were winding through the hills of afghanistan ,When they hear an aussie voice taunting them "1 aussie soldier is better than 5 taliban" he said ,So Osama sends of 5 soldiers over to sort it out ,A short gunfight erupts ,Osama waits but noone returns so they move on ,Not long after they hear the same voice taunting "1 aussie soldier is better that 20 taliban" ,So Osama sends 20 troops out to finish the job ,A heavy gunfight ensues ,Osama waits but again noone returns so they keep travelling ,Later in the evening to their amazement ,The same aussie voice fires up again joking "1 aussie soldier is better than 50 taliban" ,Osama now furious sends his remaining troops out to end it ,A massive gunfight continues all night ,Osama waits ,And waits ,Until one mortally wounded soldier returns and says to him "Don't send any more ,It's a trap ,There's 2 of them "
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
    • The frontend wouldn't go low enough because the coilover was max low and the upper control arm would collapse into itself and potentially bottom out in the strut tower. I made a brace and cut off the kingpin and then moved the upright down 1.25" and welded. i still have to finish but this gives an idea. Now I can have a normal 3.25" of shock travel and things aren't binding. I'm also dropping the lower arm and tie rod 1.25".
    • Motor and body mockup. Wheel fitment and ride height not set. Last pic shows front ride height after modifying the front uprights to make a 1.25" drop spindle.
