Hey there, just thought I'd ask for suggestions. Since getting my car(R34GTT, PTE5558, 286rwkw) back from the tune in Dec its been running inconsistently as in sometimes its feels smooth, sounds nice, requires less throttle and goes hard. Most other times (mostly always during first 10-15mins) it drives crap- sounds loud/groany/rough, requires more throttle, is lazy and doesnt feel fast, below 4k rpms feels like a boat. Running rich???
But then after turning it off then goin for a drive again while still warm it goes and sounds like it should, light on throttle, noticeably more down low and fast, sounds smooth/purry too. I had sime boost leaks (wasnt boosting to 18psi, which I fixed and now it does). But still think there might be a leak which gets sealed once warm which explains it always running crap for few mins during first startup. This is my main issue.
The other thing is first cold startup is always cough cough cough shudder shudder for 5-10secs with idle hovering at 300-500rpms then it goes up and it starts fine. This always happens. IAC i have cleaned before. But if the engines warm after a drive and I start it again theres less cough n shudder and it starts somewhat easier. Not wirried about this startup prob as its probably something minor needing a tweak.
All these probs happened after my turbo upgrade n tune (Nistune) so could it be tune related/ afm/ boost leak/ thermostat or what??
Have a slipping clutch as well which will be replaced asap.
https://www.sau.com.au/forums/topic/419900-running-very-inconsistently/
Bad tune by the sound of things, do you have a wideband O2? I've seen a few tunes from different workshops and most of them don't even touch the temp vs. injection table because they're lazy (Power FCs)
Thanks guys, I dont have a wideband and laptop unfortunately, Johnny you could be onto something, I do think its temp related- both the starting and running shit initially. Might want to see what the workshop says
What you have is probably the ignition timing problem that has plagued a few Nistune owners. I can't remember the details...perhaps shmooze the Nistune forums (in the type 4 section) for people with cold running issues. The problem is to do with the way the Nissan ECU pins the timing at a fixed value (like 15 deg) until you reach a threshold coolant temperature. This is adjustable in some ECUs, not so much in others.
The problem with Nistune is that many people think they can tune it because they see the fuel and ignition tables and adjust those, and don't realise that when you have injector size changes and AFM changes there are often a lot of other things you need to tweak, like some of the TP limits and cold start settings and so on.
Thanks man you sound like a pretty knowledgeable bloke in all areas of mechanical / tuning and car stuff, I've seen your comments in a few posts, will definitely pass your suggestions to the tuner and see what he says, but one thing with this tune, the car has returned amazing fuel economy of 13.4L/100kms (did a nice long drive plus numerous short ones last fill-up) compared to previous stock turbo with tune was always 19-20L/100kms which is really bad. Driving style unchanged.
You mean the temperature sensor? there's two near the plenum. 1x is for the ECU and 1x is for the dash. Best to drop the car off at JEM and leave it there overnight or till it cools right down and ask them to have a look with the nistune package opened and see if the temp sensor is reading correctly..
Also I can't find the thread, but I remember reading about 6 months ago STATUS mentioned that R34 GT-t had some issues with reading the ROM.. best to shoot him a message
Ok thanks mate, JEM offered to keep the car for a week, to go through the issues, I asked them if they can do a couple days, so hopefully they will find something wrong in the tune and fix it... Tomorrow my NPC HD Organic is going in so a little woohoo lolzz..
I will shoot STATUS a pm :)
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
