  • Replies 51
hard one of them nights tonight everything going great manifold almost back on nek minute stud randomly strips out of the block :( arhhh thank god for helicoils really want it back on before the weekend so i can get stuck in to other things and take it for a spin ;)
CARS GOING AGAIN manifolds back on and all going not leaking from manifold any more but is a small leak coming from where the dump pipe bolts to the turbo as one of the bolts are stripped will fix that should be easy fix hope so anyway then would like to take it to have it put on the sniffer just to make sure everything is ok with the tune and that as im not sure whats been done look it for a good drive last night and filled it up and drove 184km on highway and i had just over quarter of a tank left!! :woot: so it really really loves fule its done smell to rich and its not all black up the back of the car i believe it has something to do with the auto box and it slipping as its getting worse wont even go skids :( so sad but all that will change as soon as i get the manual in it cant wait to have it done and few little issues left and should be running good only really need to sort out the hand break and cable now...
Yes thank you damo he is my teacher and I am his grass hopper!! Solved my issue of what crossmember will fit the 25 box in to the laurel we discoved C CROSSMEMBER will fit a manual 25box in to a auto laurel with no mods :) as we have have done a test run on my mates laurel as his was already manual only had to really worrie about the crossmember and the tail shaft I already feel more confident in taking it on just hope my gearbox and other stuff turn up soon so I can get stuck in!!
all my goodies showed up today thanks to phatlavish for everything now have
-rb25 gearbox
-crossmember C (fit right in no mods needed tested this on frenchie1001's laurel the other night)
-excedy button clutch
-flywheel
-break and clutch pedals
-manual dash cluster
-laurel manual center console
-manual shifter
-all bolts for gearbox and everything
-r33 tailshaft
-manual wiring loom
-sandwitch plate
parts still needed:
-clutch slave cylinder
-clutch master cylinder
-clutch line
-r32/a31 manual handbreak
-a31/c33 handbreak cable
-mod tailshaft (going to try front 33 back manual laurel shaft
-gearstick dash surround
hope i haven't forgotten anything
havent done anything else to mine and probably wont this week been working every night this week on zacs laurel (frenchie1001) and after almost 12 months of work building it will (finger crossed) start tomorrow been a great build and learnt heaps be awesome to see it back on the track!!!
Thank you once again sir I have scored zacs hand break and front bit of the hand break line hope it will just hook up in to the where the auto hand break line splits off in to the Y just behind the gearbox and have got his bolting brackets so I can just drill the holes in the tunnel and and bolt it up just speedo now really anyone out there brought a pre made speedo drive to convert electric to cable speedo as I would rather get a good one then stuff around with the d22 nav ones and have my speedo out if I can help it!
well today i actually worked on my own laurel for a change pulled the manifold and everything back off and to find the new manifold is warped really pissed off about this as it was brand new trying to decide on what to do weather to get another one the same or try something different but im not spending $1200 on a 6 boost cant see the sense in that and i all so have bad heat problems wiring melting around the strut tower oil drain line off the turbo has melted through and the silicon bend off the turbo must of been touching as well and has done the same :( so will have bend welded to turbo and the oil drain made longer so it clears the manifold and try to move the wiring on the gearbox conversion side ive recived the the gktech clutch line very fast postage and after being stuffed around something shocking by kudos motorsports with the clutch master and slave told them dont bother after waiting weeks and weeks ive just brought a slave and master of the same guy i got the gearbox and the other parts off he has been a great help and ive found a company in NZ that can convert my electronic speedo to a cable so i can use the 25 box in the laurel so alot going on but im in no rush....
well over the ester had a awesome day at the Tasmania drift practice day at symmons plains even if i wasn't driving and and done a little to my car pulled out all the left over aircon ie pump and lines ive started on my conversion as well removed the auto shifter foot break and auto break pedal mounted the clutch pedal and clutch master and the clutch line having trouble getting the actual pin as its in the worst spot and hanging upside down in your car is horrible and with the manifold ive the flange of the manifold in 3 spots (pics to come) as ive been told it can bring the manifold back in to shape and it has so im just gonna give it ago and bolt it up but wont know till the conversion and everything is done but hopefully next weekend can get the auto box out and look at putting the manual in :) cant wait
well this weekend auto box was pulled out all the pedals done dash cluster has been changed im ready to put the clutch in now but i have never done this before so is there anyone out there with a good walk through on how to do it and what else i have to pull off as ive taken the converter off the back and the auto flywheel thing and am not stumped in what to do :/
You'll need to most likely make some relief cuts in the Auto spigot bearing then smck/pull it out of there. You'll then need to purchase a Manual Spigot bearing and smack it in with a hammer and a socket around the same size.
ok so ive need to get a spigot bearing i have a spigot bush that is like a brass bush that im guessing slips in side the bearing? i got a big bearing with my clutch that i was guessing was a throwout bearing? and i brought a small brass bearing from nissan guessing it was the spigot bush do i also need a manual spigot bearing??... sorry for the noob questions
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
