The spigot bush goes into the end of the crank. Old one out new one in.
Bolt flywheel on. Flywheel bolts are 110-120 ft/lbs
I have an old input shaft I can lend you to line up te clutch plate as you bolt on the pressure plate. This saves a world of pain. Pressure plate bolts are about 30ft/lbs
Don't forget to put the dust plate on behind the flywheel.
Box in job done.
  • Replies 51
here are some pictures of the manifold ive cut to try and get it back straight and it seemed to work but is still sitting down slight in the middle but i am betting when i got to bolt it up it will come right fingers crossed anyway...
done my hand break tonight was a lot easier then what i thought it was gonna be i used a r32 handbreak and the front part of the r32 cable with the tailshaft out and Center console out and the carpet is already pre cut from factory and you just pull it back and cut it away and youll see a oval hole in the top of the tunnel from underneth there is a plate covering the hole i drilled out 2 spot welds and pulled the plate off and there was your bolt holes and big hole for your cable to poke down through the hole and i used 2 10mm bolts and nuts to hold the cable bracket done the r32 hand break cable has a bracket on the end of the first part of the cable you have to drill that off and it will fit right up in to the the laurel handbreak cable then all you have to do is drill the holes for the handbreak its self and work out where you want it its very easy
awesome day today heap done getting the spigot bush out was so easy used grease and come out it few hits clutch and flywheel on manual gearbox on turbo housing had 90 bend welded and is all ready to do back on tailshaft has to be made to suit hope that dont cost to much im on the home stretch now had the best help from zach french sam allan and the master of all damo roach not to long till i can drive it now :)
so over this weekend ive done some of my final things in my conversion ive refit everything on the turbo side and have bleed the clutch and feels
post-93126-0-58491700-1366514279_thumb.j
and today a friend come over just to have a look at the computer and everything on it as i wanted to see if it actually had a ems ecu like the guy i brought it off said as i looked at the ecu and seemed to look just like a factory one (G8) as my friend said it may be a patch inside the loom its self but we could not work out how it was going so good with just a stock computer and putting out so much power i then started to question the poncams and if it had any at all so we took the covers off to see what it had and was happy to see the tomei are real :)
post-93126-0-89187200-1366514381_thumb.j
he then looked at the timing and said he was shocked as it was fully advanced and it can be really dangerous to the motor i dont really understand any of it and how it works as the car drove fine when it was auto i thought maybe some one else could tell me more about it??? and why it would be like this the 2 photos show what he looked at and now i worry :/
post-93126-0-01038400-1366514621_thumb.j
post-93126-0-94241300-1366514741_thumb.j
post-93126-0-55611800-1366514818_thumb.j
post-93126-0-20599000-1366514852_thumb.j
well its alive and going few issues friday night with a leaking oil drain but fixed that and is driving awesome besides the tune up high needs a little touch up seems to fuel up and break down but to drive around normal its great
mate took some photos amazing
so every one is probably getting sick of me talking about my leaking manifold problem but what are peoples thoughts about these cant find any reviews on them dont think they have been around long
http://www.ebay.com.au/itm/111050847437?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
  • 3 weeks later...
bit of news on the car the past 3 weeks its up in damos shed (DJRIFT) having wiring fixed and the manual gearbox rewired we had our ups and downs with the manifold after finding the mild steel manifold i brought pushed the dump pipe across to much so the turbo wouldn't fix and ended up staying with the stainless manifold after dr damo come to the conclusion that it was not the manifold that was at fault but the gasket as i was using a multilayer type that everyone seems to speak so highly of but the layer are held together with small rivets and that was holding the manifold out just to make it leak so i went and got a factory nissan one as directed by damo and the factory one are alot thicker spent the rest of the time pulling the manifold on and off because of stripping the thread on of the head but ended up getting it on and nice and tight and started the car was amazed NO MANIFOLD LEAK :) wiring for the gearbox was done horn and high beams fixed so i can pass pits with it then had a look at the steering as ever since i got it had very heavy steering like there was no power steering after looking it to it more found that from factory the club L laurels have a sporty steering on/off switch in the cab but never seemed to do anything when i flicked it and damo was about to power the unit up that controlled the steering and was like magic steering felt amazing just how it should he then wired it in to the ignition and works perfect now... Soo now its almost there just need new turbo and a tune get rid of that shit ebay one and get the car regoed was think of getting a quick and cheaper tune by fuletech just for now till ive saved up for the new turbo and dyno tune im happy to say its 70% done!!! :)
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
