Is it possible to fit a cooling pro intercooler kit or a hdi intercooler kit in a r34 gtt without cutting a hole for the cold side !
I have a mate that when he had his skyline a few years ago, said he installed a hdi kit with out cutting any holes .
Has any one else achieved this ?
https://www.sau.com.au/forums/topic/420171-true-or-false/
if you are keeping the standard intake plenum, and are willing to cut up the drivers side of engine bay, get pipework like this..(Gibson motorsport R31 GTSR)
If you just want a hassle free FMIC that doesn't involve any cutting of anything, then get a return flow cooler kit from BLITZ.
Looks like this..
$(KGrHqYOKigE6YOUYYu9BOv4SJobkw~~60_1.JP
If you want to spend less and still not cut any holes, then get a cooling pro/Just Jap/*insert other ebay kits here*
I sold an ARC return flow kit and replaced it with an R32 GTR core and Gibson motorsport type pipes.
https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6765765
Not sure how much room yours has down beside the radiator, and if you want to compromise on pipe diameter, but this is what I do for the s14/s15. Trim the shroud and run stainless down beside the fan.
I have also done a few custom installs, here is one with the aircon removed and the pipes through the side of the radiator. With a FFP this would be the shortest possible outcome.
http://www.skylinesaustralia.com/forums/topic/190267-summary-front-mount-intercooler-options-piping-layouts/page-3
https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6765905
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
