Is it possible to fit a cooling pro intercooler kit or a hdi intercooler kit in a r34 gtt without cutting a hole for the cold side !
I have a mate that when he had his skyline a few years ago, said he installed a hdi kit with out cutting any holes .
Has any one else achieved this ?
https://www.sau.com.au/forums/topic/420171-true-or-false/
if you are keeping the standard intake plenum, and are willing to cut up the drivers side of engine bay, get pipework like this..(Gibson motorsport R31 GTSR)
If you just want a hassle free FMIC that doesn't involve any cutting of anything, then get a return flow cooler kit from BLITZ.
Looks like this..
$(KGrHqYOKigE6YOUYYu9BOv4SJobkw~~60_1.JP
If you want to spend less and still not cut any holes, then get a cooling pro/Just Jap/*insert other ebay kits here*
I sold an ARC return flow kit and replaced it with an R32 GTR core and Gibson motorsport type pipes.
https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6765765
Not sure how much room yours has down beside the radiator, and if you want to compromise on pipe diameter, but this is what I do for the s14/s15. Trim the shroud and run stainless down beside the fan.
I have also done a few custom installs, here is one with the aircon removed and the pipes through the side of the radiator. With a FFP this would be the shortest possible outcome.
http://www.skylinesaustralia.com/forums/topic/190267-summary-front-mount-intercooler-options-piping-layouts/page-3
https://www.sau.com.au/forums/topic/420171-true-or-false/#findComment-6765905
    • Well, this, but braided line to the sender that is mounted on the chassis. Oil Pressure doesn't need to be close, while I prefer Oil Temp is in the active oil flow (bro science, not sure how much it matters).  That's how I've had mine set up for years and it works OK
    • Welcome back! There is a v series forum, a little quiet at times but every new active member helps
    • But, per MBS206's question, what happens when it doesn't start. When you turn the key to IGN, do the dash lights come on (then go off after a couple of seconds) - likely alarm or other electrical issue When you turn the key to STRT do you head a clear click (the starter solenoid trying) without the engine turning (likely starter motor)
