Hi Guys
Just looking for someone who can steer me towards the right person here....
Signed up in January and paid etc, a few weeks later received an email(Ruby) telling me to pay(already had) so replied with receipt details etc...
No response yet still from [email protected]
Trying to get my Cams sorted for mount alma and need to join up, but not sure how long all this will take along with cams bit too?
Who do I need to speak with to get things roilling?
Thanks!
Jason
https://www.sau.com.au/forums/topic/420241-sau-sa-new-membership-delays/
We have had a change in committee, and I am the person filling Ruby's spot, however he has had some personal things going on so I still haven't been given access to things, but I'll sort it out as soon as I can.
When you fill out the application form for a Cams licence, and get it signed by a club rep, you will get a tear-off bit of paper that is a temporary licence and will be valid for a month, starting immediately. You'll get the real licence in the post within a week or so, but you only need the bit of paper to enter an event. Have a look at the form at http://www.cams.com.au/en/Forms/~/media/Files/Forms/Competitor%20Forms/Lv%202%20License%20application%20renewal.ashx - this is the L2 form, not sure about other licence levels.
Once all the paperwork has been sent into CAMS it takes 2 weeks for the real photo license to arrive via mail with the pass book.
^^ as mentioned the tear off is a 30 day temp license and needs to be signed by club exec's
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
