Hello,
I have a '99 R34 GTT, its stock apart from coilovers and a pod filter at the moment. I had the joy of being able to have the track to myself and some friends the other day. While going around the track i was wondering, How far can i push the car before things will start going wrong?
Like holding it at high revs and sticking in turbo, and such how well do the stock engines hold up?
Cheers, Zac
https://www.sau.com.au/forums/topic/420335-stock-r34-gtt-engine-limitations/
Fit a decent oil temperature and/or coolant temperature gauge. If the oil heads up to 120°C, it's time to call it off. If the coolant is up over 100°C, also time to call it off.
As long as the thing stays cool and you keep the oil filled up and the fuel tank above half full, you should be able to cane the engine for longer than you can handle before it will die.
Having said that, brakes and tyres usually go off on the track before anything else mechanical will suffer. Street pads don't handle continuous hard use.
That's awesome, everything stayed really cool on the track. Although i wasn't going as hard as i could have been by the sounds of it.
I did notice my brakes weren't the greatest on the track, they're the next thing to replace on my list.
I've always been told about horror stories of pistons going through the block and such, and to be honest it scared the shit out of me. Next time i'll give it a tiny bit more then
If your not limiter bashing there should be next to no chance of engine damage unless like has been said your hitting high oil or coolant temps.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
