G'day ladies and gentleman.
SAU:SA is proud to announce The SAU:SA Pool Night. As a special one of offer, SAU:SA are offering a generous sign up offer. Sign up to SAU:SA on the night of the event and the $15 admin fee is waived, plus you get a bonus of 4 months membership (ie membership is going to be valid till 1st July 2014).
This is a perfect opportunity to meet the new exec team and be able to put some names to faces.
Venue: Empire Pool Lounge
Time: 7pm - 11pm
Date: Friday, 15th of March
Special Offer: Signup on the night with SAU:SA and receive $15 off admin fee plus a bonus of 4 months membership.
Cost: This is a FREE event
This event is open to current active members and non members as well.
Need numbers confirmed by 11th of March!
Hope to see you all there :D
Current Numbers
Krishy - confirmed
dark.sky - confirmed
Race_24 - confirmed
Fiiggy - confirmed
illmatic - confirmed
ahhbee - confirmed
Brotato - maybe
Grimesy - confirmed
Miss V35 GT - confirmed
Nathan1066 - confirmed
Deep Dish V35 - confirmed
Aberax - confirmed
SAMR326 - confirmed
On Edge - confirmed
pistol-pete - confirmed
gilly-R33 - confirmed
https://www.sau.com.au/forums/topic/420398-sausa-pool-night/
  • Replies 43
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
