Hey guys, i havent been on here in ages! been busy and what not, so here it goes.
cars been extremely good behaved for the last year or so. Servicing it on time, everything .
Untill last night.
Was driving fine, until it felt like the auto was being a C**t first and second arent too bad. Thirds ok, 4th is not holding. i dont know how to explain it.
is this telling me the Auto is Rooted and its time for a manual conversion? or am i going bananas and need to fully flush the auto . I did service it not long ago
Any help would be great.
Btw : In overdrive it drives somewhat ok.
im kind of nervous and worried.
A very unsettled willzgtst.
Cars not running any mods. apart from pod filter.
https://www.sau.com.au/forums/topic/420530-r33-auto-gearbox-issues/
could be any of a lot of things wrong with it. .(even the convertor) very good idea on the flush but before you do that id be checking the filter screen after you drop off the pan, depending on what / how much crud you find on the screen will be the deciding factor as to wether its f*kd or not
Can you be more specific with the symptoms?
"4th is not holding" - does that mean it feels like the internal clutches are slipping/flaring, or is the shifting going haywire eg going up and down in gear and power constantly dropping off.
Check the throttle position sensor. If it goes faulty the shifting goes haywire.
Ok basically up to third is ok , once in fourth as soon as I push the accelerator down it kicks back but it feels like it's slipping if I let go of the accelerator slight it drops the revs , I have been driving in overdrive as that's the only way it's drivable ATM .
probably the best idea is to replace it with a good secondhand unit with warranty, they are going pretty cheap.(rebuilds are over $2000) . . while things are apart i suggest you get a tranmission cooler fitted
all running smooth and fine. dump pipe was put in so thats a bonus also. u can really tell the difference between healthy autos and unhealthy , this gearbox changes gears where it should. The other one would wait for me the lever the accelerator and if i didnt, it would slip and take its time.
Thanks for all the support fellas! :action-smiley-069:
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
