Hey guys sorry to open another wheel thread but i am looking at buying my new wheels tomorrow, I have read countless threads and am sure these will fit fine but just wanted to double check with you guys before hand. The new wheels are 18 x 8.5 and 9.5 inch +30 which i understand to be same as stock 18's just a tad wider. So was just hoping you guys with a higher knowledge then me could let me know if these will have a nice fitment that is going to be legal and all.
Thank you for any help you may give. Almost forgot to add....its a coupe =)
https://www.sau.com.au/forums/topic/420621-rim-help/
yeah +30 is a bit weak, i learnt my lesson when i bought +25 offset wheels.. they sink in the guards pretty bad but i didn't want to run spacers for insurance purposes. I'd look for wheels with lower offsets or consider spacers.
https://www.sau.com.au/forums/topic/420621-rim-help/#findComment-6765464
Yeah im looking at these - http://www.importmonster.com.au/shop/product_info.php?cPath=40_45&products_id=1322 have seen them with a +20 also so might get on and ask the guys if they can get em lower then that if not ill just keep my eyes peeled for something similar.
https://www.sau.com.au/forums/topic/420621-rim-help/#findComment-6765823
Yeah been tossing up on if i should get 18's or 19's dont really wanna get 20's like i did on my last car tyres cost to much and I enjoy having a functional spine after a long drive. And yeah im the same as you gonna try steer clear of spacers so i cant have it used against me by my insurance.
https://www.sau.com.au/forums/topic/420621-rim-help/#findComment-6765845
might be an idea just to save a bit more money, and spend it on a quality set of japenese wheels with the right offsets in a 19''. Tyres are still going to be expensive in a 19'' too.
Edited by Seano350GT
https://www.sau.com.au/forums/topic/420621-rim-help/#findComment-6765865
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
