hey guys
selling off my project car r33 gtr i only really just bought it but have moved onto an r35 haha.. cant afford both, especially with r35 parts being as expensive as they are.
ALL PARTS LOCATED IN MACKAY NTH QLD, POSTAGE CAN BE ARRANGED
I CAN ALSO POSSIBLY TRANSPORT THE SHELL TO BRISBANE OR NEAR THERE PROVIDED I HAVEN'T SOLD THE WHEELS OR ANYTHING ELSE TO MAKE IT DEMOBILISED!! WILL ALSO NEED A MONTHS NOTICE AS ITS A 1000KM DRIVE AND NEED TO ORGANISE A TRAILER OFF MY MATE..
R33 Gtr mnp shell it is complied and DID have rego a couple years ago (nur33's old shell) - $1500
  • Front windscreen cracked
  • Stripped interior, not one bit of wiring harness front to rear
  • Front guards modified as per picture
  • Custom dash reo bar made
  • Custom alloy dash made
  • Sound deadening partially removed - just the stuff i could get with dry ice.. Some still baked on like around the gbox tunnel
  • Front radiator support cut out - was planning on welding a couple tabs to it then bolting it back on via the tabs
  • Lower front chassis brace cut out and replaced with a piece of tube to give the radiator more room and be able to have the intercoler sit upside down and have its inlet and outlet very close to the intake mani and turbo for short piping.
  • all fuel and brake lines have been removed
  • aerocatch bonnet pins
  • led taillights
  • will throw in the whole car loom and all ecus that i have.. loom is cut in a few spots and one ecu is damaged.
  • NO DIFF!!
additional parts to suit.. if you buy the shell the below parts will come at a discount depending on what it is you want.
  • r33 gtr BC External Reservior coils, as new only fitted and moved 50metres - $1350
  • r33 gtr black oem front bar, good condition paint is scratched a bit - $500
  • r33 gtr/gtst greddy front strut brace - $125
  • r33 gtr carbon fibre grill with no symbol just mesh - $100
  • r33 gtr rear wing, carbon end caps - $350
  • r33 gtr front lights very good condition - $350
  • r33 gtr/gtst cusco hicas lockout bars very good condition - $250
  • r33 gtr cusco front swaybar - $250
  • r33 gtr moonface racing castor arms - $200
  • r33 gtr passenger seat, good condition - $250
  • r33 gtr front drive shafts - $400
  • r33 gtr rear driveshafts - $500
  • r33 gtr front propshaft - $150
  • r33 gtr main propshaft - $300
  • r33 gtr rear strut tower/boot bracing, not the bar that goes from tower to tower but the bracing that bolts to the strut tower and boot floor - $150
  • r33 gtr bonnet, mnp with genuine uras bonnet vent - $450
  • r33 gtr interior panels, have a whole bunch of them, pretty much only threw out everything in the back half of the car and the dash - not sure what condition it is all in these days so if you want something i will have a look and see if its there then get back to you with a price.
Aftermarket Stuff
  • GTR Trust Drag intercooler 600x300x150mm, VGC, part of the end tanks chopped off for the different orientation i was planning while running it upside down - $1900
  • Stack 8130 dash - excellent condition has all loom, oil pressure and one temp sensor.. needs one more temp sensor to complete it - $1450
  • Full Set r34 gtr standard brakes with slotted front and rear rotors, rotors have been painted to keep rust off - $2000
  • AME TM-02 wheels, 18x10+15 all corners on 1000km old achillies 123s semis 265x35x18 - all very good condition no gutter rash - $2300
  • rochester 14mm 1200cc injectors x 4, never been used only fitted - $400
  • buddy club fixed back seat, has rail to suit s13/4/5. black with grey inserts for a normal sized person, has a small tear in the fabric other than that its as new - $450
  • sr20vet mazworx lhd or RHD without brake booster intake manifold, no fuel rail as new condition just needs a throttle cable bracket welded on - $500
  • s13 whiteline front swaybar good condition - $125
  • S14/15 K.L.S camber arms - $85
  • 2jz exhaust manifold 3d flange ready to make a manifold - $100
thats it for now..
please contact me (spencer) on 0413347774 or via pm
as requested, a picture of the bonnet. only one i have thats half decent.. i can get some better ones on the dslr tomorrow if you want? bit dark atm
also has aerocatch bonnet pins fitted now instead of the ones pictured and forgot to mention the n1 lip
Hey
So far the rear driveshafts are gone and front bar, had intrest in the suspension and most likely sold the brake master cylinder.. Other than that it is still how it looks in that picture minus the autoselect lip..
Send me a pm and we can work a price out depending on what you want to come with it..
  • 3 weeks later...
  • 6 months later...
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
