Thanks skyginer.
Looking to paint the car now it's off the road for a bit as the converter ate itself on the weekend so I think I will do a rack and pinion steering conversion e85 and paint job over the next few months.
  • 3 months later...
Gearbox fixed again. New ecu lt16c with flex fuel and dash installed drives and runs smoother than the lt12 that was in it before. Just waiting for a drum of e85 to arrive to finish if the flex tune.
Looks like I might be looking for a bigger turbo now the gearbox is sorted. Lol
I hope it all works for you,
Gearboxes must be getting hard on the pocket and with the extra power comes extra stress on everything.
But it is all part of modifying these things , trying to get it all to work together and hope you have not over done it, haha
Hard not to try and get what you want from your ride without going that little bit further to get it :)
Lucky for me the guys at mv in Adelaide have covered most of the cost under warranty. No chance of being over it yet. If it was easy everyone would be doing it that's what I keep telling myself anyway. Lol
  • 1 month later...
  • 3 weeks later...
  • 4 months later...
  • 9 months later...
Been a while since any updates. Retune with 6boost and new cooler pipes was 350kw on 16psi. Car is apart finishing r31 rack conversion as no one can rebuild the steering box. Also modifying the rear control arm mounts to make them adjustable. Will add photos over the next month.
  • Like 1
  • 1 month later...
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
