  • Replies 71
Im out guys... Just finished giving the car a good check over and it is not ok for circuit... Front tyres inner are worn to the canvas...  :rofl::P
Next time maybe
sam, no worries mate. catch you next time
I am keen fella's........ Live in Miranda..... Will meet up at the caltex.... at around 6
mike we'll wait til 6:15 max for ya
i'm on 0402 287 773
btw boys, just got home. piss drunk. i should be in good form on the trak hehe.
cheers, MARK
You too mate. I had some underboosting problems as you might have seen. Got a bit sick of it after a while so I went home about 3ish I think.
Good to see you enjoying yourself.
I had my intercooler pipes off when I heard they were taking photos there. damn. might have given you a run for your money.
my gf took some good footage of my hands around some of those corners. pretty funny to watch.
haha run for my money? you nailed me hehe. you were SUPERB in drifting the corner into the main straight. looked bloody fantastic!
did anyone go to the OZEVENT photos shed?
hmm the owner's daughter was top stuff. geez I liked her!
anyway see you there next time boys.
cheers, MARK
imagine getting to do a full circuit lap of wakefield.....bastards :)
at one point I had the track to myself for 10 mins
beautiful stuff. who needs racing brakes, racing tyres etc
buy a shitbox old car. and go out and thrash it I say!
me had a great time, not too many cars on the track. had even more fun chasing/hounding the yellow monaro coupe. thanx to tosh for teaching/showing me the race lines on the track.
sunday wasn't too crash hot as there were too many race cars/categories which meant not getting no where near the amount of track time that myself and everybody else that came on sat.
looking forward to the next event at wakefield.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
