S A U - N S W Tech Night For Members 24Th Apr - Engine Builds
  • Replies 195
We're right 'on the money' now Ricky - so we Execs won't need to ask for confirmations now.
Your attention to detail though is to be applauded!
Look forward to meeting up with you and all the other eager beavers on Wed!
Mmmm beaver... :blink:
are we going to meet for dinner beforehand?
there are a couple of fast food joints nearish.
We will be running late so no can do on the foodz man!
Bobby has kindly offered finger food for those in a rush.
Don't get a ticket though!
There is no decent place to eat right near JEM so I might have to go a Km away.
Their floor is generally clean enough to eat off if that helps :P
We will leave Newcastle at around 4.45 so we wont be too late...
lol turbo used as a food processor
With some of the turbos i have seen you can be assured the food will be blended VERY well! Take that falcon drag car for example :P Dont even need to lift the bonnet to get to the turbo haha
Woodbine is about 4km from JEM. At the intersection there is every type of fast-food you can think of. Including Hooters :)<br />
Awwwwww yeah :yes:
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
