Probably thats what I will do, chuck in softer springs and since its a street car only now, if it goes alright, I will just leave it. I have yet to get verniers and come up with a more accurate measurement of the spring wire thickness though..
No, when the vehicle is on the road, the helper springs should be squashed to binding.
I wouldn't put softer coilovers on teh rear only. If your fronts are like 12 or 13 kg/mm, then the BC rears at (say) 8kg/mm will be too soft (by comparison) and the car will understeer like a bitch. You might make it work if you pulled the front ARB off it and ran a fairly thick (like 22 or 24mm) rear bar.
Ok so got verniers today for extra accuracy.
Spring wire dia is 12.5mm
Spring outer dia is 89-90mm
No of 'active' coils is 6
Spring rate from a couple of US sites is 9kg/mm and thats for the rear- f**king hard hehe
Fronts are 10.7kg/mm at 13mm wire thickness, all else same.
Should I run n get 9/7 springs as two sizes down are acceptable or should I go out of bounds n get 8/6 which is still hard??
I would buy a set of 6/4 springs and try them. They'll not set you back too many $$ and you can probably offload them to someone else if they simply don't work against the dampers. But if perchance the damping is not ridiculous, then you may just end up with a very firmly overdamped ride, which you could at least live with more than the simply rock hard ride that you'd have now.
Plus, you may be able to sell your current springs to a track junkie.
I went from 10/8.5 down to 8.2/6.4 and they're still very stiff - too stiff with the crappy roads i use. It was a noticeable improvement tho. So - IMO 9/7 is a complete waste of time, 8/6 would be the hardest you'd want to think about changing to, though i'd guess less than 8/6 would suit you better.
Thanks man, you guys are brilliant, Otomoto is 5mins from my place and have the HSD springs in various rates which look about the right size as well, 200mm long, 65mm Inner dia etc; now the dilemma is whether to go 6/4 or 7/5 from 11/9 which is a huge drop - you all have different opinions - I would love 6/4 but dunno if the dampers would cope, 8/6 would be more matched but then its too hard so :wacko:
  • 3 weeks later...
Update: bought 5kg HSD springs from Otomoto, dismantled rear ( a real pain of the job in the dark with no ratchet spanner for rear coilover bolts- really hard to access those f$&@ers), well finally put them in. The HSD coil inner dia is about 1.5mm larger than the Cusco coils so there is some left-right play against the top n bottom sleeves. Texted Jez and he said it should be ok- legend. Put it all in ( fronts are still Cusco 10.8-11kg springs) and went for a drive, feels somewhat softer and DOES grip better - less wheelspin in first and second and more traction but not by too much, but a reasonably good improvement I would say. Doesnt ride funny or bottom out as I had thought with damper n springs not matched right.
The car sat like 7-10mm lower after I installed the new softer springs in with coilover height untouched and spring preload about the same hand tight. So I raised it up that much to get more travel for the struts and less -ve camber for the wheels- win win. So I have yet to change the fronts- to 7kgs. Thinking I might go 6kgs as 5kgs from 9kgs for the rear didnt screw up my damping..
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
