GTR for sale.
512rwhp @22psi, 475rwhp @17psi.
Crank HP will easily be over 600, awesome for twin low mounts.
The car is a 1993. A private import in around 2002.
I purchased the car in 2004, I kept a spread sheet with money spent on the car but I stopped updating that when it reached $80K!
The engine is fresh and is tuned by Scott at Insight.
I have just fitted a new CAS as Scott was not happy with the last one.
When I rebuild the engine I also made a number of other changes, they are listed below with the parts used in the rebuild.
Engine details
Recent engine rebuild:
- R33 bottom end.
- Eagle rods and JE pistons.
- Performance metalcraft sump extension.
- JUN oil baffle extended.
- Nitto oil pump.
- ARP head studs.
- Genuine Nissan gasket set.
- Gates racing timing belt kit.
- ACL bearings.
- Nismo engine mounts.
- Nismo transmission mounts.
- ATI harmonic balancer.
- Nitto valve guides.
- Aux oil drain from back of head to sump.
- Rebuild turbos.
- New wastegate actuators.
- Ceramic coated manifolds and dump pipes.
- Nissan geuine CAS.
- HKS fuel pressure regulator
- HKS duel feed fuel rail.
- Nismo fuel pump.
- Greedy hard pipe intake kit.
- BMC pod filters
- HKS inlet manifold gaskets.
- Koyo Alloy radiator.
- Davis Craig thermo fans (not currently fitted)
Parts reused from the old motor that were still good.
- Mines cam baffles.
- Sard 700cc injectors.
- Tomei cams
- HKS 2530 turbos (rebuild by Precision)
- Split fire coils.
- HKS super sequential BOV’s
- HKS oil cooler and remote filter (huge)
- Apexi drag intercooler (huge also)
Some other notes about the engine.
- The computer is a VipecV88 running a map sensor.
- The battery has been relocated to the boot and a custom catch can is where the battery was.
- The catchcan is plumbed back into the intake.
- The HKS BOV’s are plumbed back too.
- Innovate LC-1 wideband with guage in space of factor boost guage.
- Blitz dual solenoid boost controller.
- Power steering cooler.
Chassis details
Gearbox was rebuild by Terry at Award diff when the engine was being rebuilt, he earlier rebuild the rear diff.
Clutch is OS Giken STR twin plate. Fantastic clutch, easy to drive and also holds the power.
Suspension is MCA/Proflex custom with remote canisters. Fully adjustable. Amazing shocks, MCA was in the Targa winning White GTR and also in the world time attack cars.
A Ruzic 4wd controller is fitted, sits in the glovebox.
The HICAS has been removed including all the pump and lines. The rear stage of the power steering pump which feeds the HICAS has been rerouted to a cooler.
Both prop shafts have had been overhauled.
Front lip is new and genuine Nissan.
New clutch master cylinder.
Custom adjustable front upper arms, good for about 4deg negative static camber.
Nismo chassis bracing, one under car and one in the boot.
R33 wheels painted R32 grey with Advan V103 255/40/17. Tyres are good. Fronts are 90% left, rears about 50%.
Race R33 wheels also painted R32 grey with Toyo R888, 90% left.
AP 4pot front calipers.
DBA 5000 front rotors with alloy hats.
Custom 6mm T6 alloy undertray to protect the intercooler and sump.
Whiteline swaybars.
Noltec rear bushes all round including the rear subframe.
Interior details
Interior is very good.
A Cusco 6point bolt in cage is fitted.
Seats are Bride LowMax Carbon with reclining.
Seat rails are Bride super low.
When I fitted the cage my helmet would hit. I didn’t want lots of padding on the cage so I spend the money on the seats and rails.
Sparco steering wheel.
Pioneer touch screen system with good speakers, amp and subwoofer.
Price
I would like to sell the car as a complete going concern. I built this car to be the ultimate street/trace GTR and I don’t want to mess about pulling stuff off etc. So both sets of wheels are included.
My old spreadsheet was upto $80K before I stopped updating it, plus the $12K on the engine parts and $3K for the seats I have no doubt I have spent over 100K on this car. I will be happy with $30K.
The track wheels, track rubber, cage and seats should be good for $5K, so $25 for the car is a bargin.
Please SMS me your interest and i will call you back 0412 697 308 or email [email protected]
https://www.sau.com.au/forums/topic/420966-1993-r32-track-ready-600hp/
Nice car mate glws they are easy to sink money into must suck loosing that much though lucky buyer who ever buys it, I'm going through the sinking money stage now but not 80 k or at least I hope not lol
My preference is to sell the car as a complete package but will offer it in 4 different configurations:
1. Complete package as listed above. $30000.
2. As listed above but without the 2nd set of wheels with almost new Toyo R888. $28000.
3. As listed above but without the 2nd set of wheels and without the cage. $27500.
4. As listed above but without the 2nd set of wheels and without the cage and with stock seats. $27000.
I will have to source the seats for the 4th configuration. So I cant be sure of their quality will match the rest of the car.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
