R33 GTS-T Turbo auto dark grey/silver sedan series 1 with sunroof, Full car wrecking, driver side front end damaged, bonnets gone, radiator gone, A/C condenser gone, headlights gone, driver guard gone.
All parts available, located in Fairfield West NSW. Pick up over postage (can post any parts aus wide at buyers expense).
RB25DET complete engine no turbo - $1300
Front bar - $150
Rear bar - $150
Tail lights - $200
Boot lid (has spoiler, 3 PCS) - $100
Door (shell only) - $150 each
Full door (including trim, switches, window, regulators etc) - $200 each
Sunroof kit - $900
tock wheels - $300 (one flat tyre)
Complete seats - $200
Floor mats, fair condition - $50
Autotechnica Steering wheel - $50
Stock exhaust - $150
Stock shocks - $100
Turbo calipers full set including existing rotors and pads - $650
Control arms - $100 each
5 stud Hubs - $150 each or $500 full set
Non ABS BM44 BMC + Booster - $100
More parts to come, just ask! Happy to take reasonable offers. f you have questions, POST HERE. If you want to buy, PM me!
can you show some pics of the sunroof kit?
Will have them for you shortly. Haven't pulled much off the car as of yet but will do so tomorrow.
  • 4 weeks later...
looking for a full 33 rear end?
Sedan or Coupe? Cannot supply sedan but can supply Coupe. Though logistics may be a problem.
  • 4 weeks later...
  • 1 month later...
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
